Need Help with MS-8 Crossover Setup
09-01-2015, 10:00 AM | #1 |
52
Rep 271
Drives: 2016 340i MPPSK
Hello, I need help with the MS-8 setup, specifically with setting the most optimal crossover freq values.
My speaker and amp setup is currently: Front: Focal IFBMW-S (amped) Center: Focal 100CA1 (amped) Rear: OEM L7 speakers wired in parallel (MS-8) Underseat: SWS-8xi (amped) I tried the following crossover and it sounds a bit hollow: Hi Pass: 20hz / 24db All speakers: 160hz / 24db What I do when I do the initial setup, I turn down all the gains in the external amps all the way down. I configure the MS-8 (crossovers, acoustic measurements) first, then whebn I am done configuring, I turn the gains on the external amps back up to my liking. Is this how to configure the system? I appreciate any advice you can give me. |
09-01-2015, 06:36 PM | #2 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
09-01-2015, 09:54 PM | #3 |
102
Rep 952
you really should not be messing with the gain post calibration unless you trying to something specific (am I reading your post right?). Your gains should be should be in the ballpark before you calibrate....
also...."hollow" is how I would typically describe an out of phase set of speakers....so double and triple check the phase of your speakers. |
09-01-2015, 10:53 PM | #4 |
52
Rep 271
09-01-2015, 10:59 PM | #5 | |
52
Rep 271
If that is the case, what about the amp that is powering SWS-8x? Should I raise the input BEFORE MS-8 calibration? For my external amps powering the front, center and sws-8x, I have set them to "All Pass" and frequency knob all the way down. Please let me know if I should set it otherwise. Sorry I am a newb at this.. |
09-02-2015, 12:37 AM | #6 |
729
Rep 1,815
Try bringing the highs and mids up to 200hz HP Why are the rears run in parallel? this defeats the purpose of the MS-8 surround capabilities.
All of your amplifier crossovers should be set to all pass or full range. You big problem is the SWS woofers. You will have a better SQ with running the stock L7 underseats.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
09-02-2015, 07:23 AM | #7 | |
52
Rep 271
I need confirmation whether I should turn up the external amp levels to match the volume level with the rear sides that are powered by MS-8, when calibrating MS-8. |
09-02-2015, 08:20 AM | #8 | |
281
Rep 4,121
Also wiring the rears and sides in parallel is the only way that ms-8 has enough channels when used with a center. This is the recommended configuration by Andy W. The second paragraph is correct. The sws cannot handle midbass so stock midbasses either hifi or L7 are better if you use a trunk sub. Without a trunk sub its a tradeoff you have to decide for yourself; better modbass or sub bass. With those focals you may be able to use a low enough crossover point to pull it off. |
09-02-2015, 08:27 AM | #9 | |
52
Rep 271
09-02-2015, 08:27 AM | #10 |
102
Rep 952
Yes, you should get the levels roughly similar before you calibrate......then leave them alone post calibration, use the ms-8 level controls and eq.
As taibanl said, with the specific speaker setup you have, the crossover point needs to be as low as the focals will go, 160 is good, lower may be even better. |
09-02-2015, 08:29 AM | #11 | ||
281
Rep 4,121
09-02-2015, 09:00 AM | #12 |
52
Rep 271
Thanks guys, I will try to match the levels using an db app, then calibrate at 140hz or so and report back with the results.
Thanks. |
09-02-2015, 03:18 PM | #13 | |
729
Rep 1,815
The SWS speakers do not have the frequency band that the Stock logic 7 woofers have and believe it or not, they will take more power than the SWS will take without breaking a sweat. (Trust me)
09-03-2015, 07:23 AM | #14 | |
52
Rep 271
Wow. What a huge improvement even though it was a rough measurement. I can't believe I was listening to unbalanced sound for the past 2 years.. I plan to use the hidden test menu to match the sound level more accurately then recalibrate during the weekend (it was night time yesterday). Thanks again guys! You guys are awesome! |
