09-01-2015, 07:14 AM | #1 |
73
Rep 201
Rear Brake Upgrade/Conversion Pros/Cons?
I have an opportunity to get some Porsche OEM Brembo rear calipers for a stupid good price. They are 4 piston (mine stock are 2 piston). The conversion kit is designed for an E46 M3 Details Here
Questions I have are 1) Will these fit a 2015 M235i (F22) ? 2) Even if they did fit is there any benefit ? Thanks
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
09-01-2015, 09:04 AM | #2 |
463
Rep 957
Benefit:
Have to custom make a mount, try to find rotors that fit. Pay Porsche consumable pricing. Honestly the only benefit you will see is totally messing up the brake bias. Car will drive like a trailer brake dragging from the rear. You would also need to do the fronts to 6 pod to make the system work. There are some kits out there with floating rotors 6 pod font 4 rear. But they are prob 4-5k. I cant see much of an advantage as the brakes on this car with race pads are great. Spend the money on track days driving. |
09-01-2015, 09:16 AM | #3 |
73
Rep 201
Thanks for the input. Needed to ask cause the price I was offered is phenomenal. Practically free. I had googled the brake bias to see what the effects were. Played enough gran turismo to guess there might be some effect. And without a bias controller i can see how it might be a pain.
09-01-2015, 09:23 AM | #5 | |
73
Rep 201
09-01-2015, 04:43 PM | #6 |
1538
Rep 3,331
Don't see why this would be worth a cent of your money to try to retrofit.
The rear brakes do very little work compared to the fronts, and the M already has very capable stoppers, which can be made more capable with a high temp fluid or more aggressive pad. So other than filling out the wheel well with a mismatched caliper there is zero point to this. If you are unhappy with your brake performance there are steps you can take, if you're trying to modify a complex piece of engineering based on a good deal from a friends leftover parts...then beware.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
