Rear Camber Adjustable Arms
08-29-2015, 04:49 PM | #1 |
15
Rep 188
Does anyone have a DIY for replacing the rear camber arms? I've got rear toe arms and rear camber arms coming in on Monday and was thinking about changing them out myself. I know the rear toes you just have to remove those M12 bolts and bam you're good but what about the camber arms? I can't seem to find any pictures or any DIY on it.
E46 325i-RIP
E92 335i- BMW PS|M3 Front Arms|FMIC|DPS|ER CP|DCI|JB4|Connect Kit|M Delete |
08-29-2015, 05:28 PM | #2 |
4276
Rep 9,209
Is the same procedure. You just remove the bolts.
This link will give you an idea: http://www.pelicanparts.com/BMW/tech...eplacement.htm But why are you replacing the lower control arm? |
08-29-2015, 06:53 PM | #3 | |
15
Rep 188
E46 325i-RIP
08-30-2015, 08:02 AM | #4 |
4276
Rep 9,209
Yes, I misunderstood you, sorry about that!
This link might help you: http://www.pelicanparts.com/BMW/tech...eplacement.htm |
08-30-2015, 03:51 PM | #5 | |
15
Rep 188
E46 325i-RIP
08-30-2015, 05:35 PM | #6 | |
146
Rep 1,160
Camber arm's the big mama yer shocks 'n' springs're mounted on. There is no other arm to adjust camber.... Regardless, ain't rocket science for any suspension arm: Unbolt & remove; reverse procedure w/new arm. Naturally you'll want to support the wheel and if necessary loosen other arm bolts/nuts so the suspension can move around if you're having trouble fitting the new arm in. And we always work with a calibrated torque wrench....yes. But there is one thing to know: If you're R&R'g the camber arm you need to support it with a floor jack coming out & going in. Why? 'Cause the spring's compressed by the camber arm. If that doesn't make sense, time to back way, way up and re-evaluate until it's fully understood what's involved! And: You'll need an alignment when done. Unless....you live for danger! |
09-03-2015, 09:51 PM | #7 | |
Where'd my VTEC go?
481
Rep 6,067
But yes, stock camber adjustment is only via the lower control arm.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
