08-24-2015, 08:30 PM | #1 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
My JB4 logs as requested, 26.7 PSI
So people have been asking for awhile to see my JB4 logs, well here they are
Ive been messing around with DB tuning, and I still have some work to do but here we are! this is on an E40 mix, 100% meth spray. Also I have the timing trick installed so my IAT's are showing about 40 degrees higher than reality. [IMG]Untitled by blutorrent, on Flickr[/IMG] [IMG]Untitled by blutorrent, on Flickr[/IMG] [IMG]Untitled by blutorrent, on Flickr[/IMG] http://datazap.me/u/obriennathaniel/...log=0&data=1-4 http://datazap.me/u/obriennathaniel/...log=1&data=1-4 http://datazap.me/u/obriennathaniel/...log=2&data=1-4
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
08-24-2015, 10:48 PM | #2 |
1078
Rep 2,358
You are overboosting quite a bit up top because your FF is too high compared to your PWM. Play with Duty Bias to get that under control. PWM not even 100% if I read it correctly - crazy haha
I gotta get that Stg 2 :P
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
08-24-2015, 10:50 PM | #3 |
515
Rep 1,063
Lol not even! But yea I'm still messin around with the duty bias. It was perfect before I upped the boost to 27, it should be a pretty simple change.
08-25-2015, 10:28 PM | #5 |
1078
Rep 2,358
http://www.n54tech.com/forums/showthread.php?t=29893
FF is globally controlling/scaling (together with a bunch of other parameters) the PWM signal to the turbo DB (duty bias) is doing the local scaling In other words - if you get over/under boost in certain areas you can use DB to finetune. ...hope I got that right
(A Dane in China) |
08-26-2015, 03:58 AM | #6 | |
515
Rep 1,063
