E70 Top-HiFi amp retrofit.
08-24-2015, 12:26 AM | #1 |
T667YM86
67
Rep 244
Hello.
I have had pre-LCI E90 with Stereo system, non-Idrive (BMW Professional). I have replaced stock speakers with Jehnert 3-way kit and then succesfully retrofited E70 Top-Hifi amplifier (AMPT70). Retofit was easy as far as I already have MOST in trunk (CDC, ULF). Just run wires, solder pins, code 677 option and set jumper on pins 1+2 in MOST socket of amplidier. Now I have two problems: 1. Underseat woofers has no filtering (or at least it's not correct ) from AMPT70. Jehnert woofers now plays too high (>250hz) and too low (from ~ 30hz). I have to lower 200hz on min and even then I have +3db peak on ~200hz. I also have +3db peak on 40hz (car interior resonance), when Jehnert recomment HPF 60hz for their 8" woofers. 2. Low volume of PDC beeps. Front and rear - the same low. There are no PDC-Volume setting in head unit. Question - is there are any parameters in RAD (RAD2) module such as PDC-Volume and X-Over freq\slope?
E90 325i 05MY, ZSP, Koni Sport, Eibach Pro-kit, BBS RK-II squared
08-27-2015, 04:28 PM | #2 |
886
Rep 9,097
Kudos to you for doing that.
Why was e9x L7 not used? Unfortunately, you cannot tweak the amp xovers. Rad2 / 3 does not allow you to tweak it via coding. Check the equaliser in the unit and use -db for 100hz.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
08-27-2015, 11:01 PM | #3 | |
T667YM86
67
Rep 244
P.s. I don't know what IC used in E90 Logic 7 amp, but AMPT70 uses 7 dual channel class-D IC. AMPT70 have passive cooling, when E90 amp uses 2 40mm fans, so I guess E90 amp uses class-B IC, like E60 and E65.
08-27-2015, 11:55 PM | #4 |
1911
Rep 13,103
FYI this has the chips used in the e90 L7 listed
http://www.e90post.com/forums/showthread.php?t=1144129
The power IC chips are listed in entry 18 in the above thread. The spec sheets are in the links in entry 18. |
08-28-2015, 07:52 AM | #5 |
T667YM86
67
Rep 244
E90 L7:
2x75wt class-H 5x(2x25wt) class-B all for (4R load) max power E70 AMPT: 6x (2x80wt) class-D (4R load) max power
09-03-2015, 08:09 PM | #6 | |
128
Rep 525
What additional wires did you run, What do you mean by solder pins and What's the jumper for pins 1 + 2. Any pictures you have would be awesome. Been looking for this information for months. |
