Auto Start Stop Failure
08-23-2015, 03:57 PM | #1 |
28
Rep 306
Hi guys,
Basically my battery went and gave up the ghost so I replaced it, not thinking I fit a non "start stop" battery and the car threw loads of faults. I returned the battery and refit my old one until the parts shop could get a start stop battery in stock, the old battery miraculously fixed itself and to this day (touch wood) holds charge for ages and is fine to use proved by ignition on and the radio etc works for hours. I used tool 32 to register a new battery on the car but I still have an "automatic start stop failure" message that comes up every time I start and stop the car, Just wondering if anyone know how to reset the system or code the system out or anything as resetting the fault doesn't work and it re appears? Any help would be greatly appreciated ! Chris. |
08-24-2015, 03:43 AM | #2 | |
283
Rep 2,796
Therefore you needs to obtain a AGM spec battery, to the same specification that you currently have. they range from 70aH to say 90aH BMW battery's for instance cost between £139.71+VAT to around £165.71+VAT, you can buy S5/S6 from places like Euro's, the Euro's supplied battery's will have a better warranty, BMW's only come with a 24 month warranty, but on the battery front get the numbers off the OEM current battery before ordering from Euro's (they usually want to know the size of the battery in terms length width etc.-but the part number should sort this issue out) Coding wise if it is done correctly and everything is initialised you should be OK, but after market tyre equipment wise for registering battery I have no idea only know BMW ISTA, Autologic |
08-24-2015, 05:10 AM | #3 |
175
Rep 1,596
If you've got tool32 you should have INPA as well...
Do a full scan for fault codes, there should be something logged which explains why it has disabled auto-stop-start. |
08-25-2015, 12:43 AM | #4 |
28
Rep 306
Thank you to both of you for your responses!
Steve - tool 32 was used to instate the new battery and the original battery went on so I know the spec is currently ok with the battery but this may be a cause I'm not sure Aragorn- it's a friend of mine who does all my coding so I'll get him to run his software for me he does have INPA as I've seen him on it before so I'll try and get that done in the next couple of days and report back with the fault codes if you could help with them? Thanks guys |
08-25-2015, 01:48 PM | #5 | |
283
Rep 2,796
08-26-2015, 01:52 PM | #6 |
28
Rep 306
Hi guys,
Just done a quick code read on my car via INPA It has the listed faults as follows; 416F (DME/DDE module) 4B2D (DME/DDE module) 4A6E (DME/DDE module) Any help would be greatly appreciated as I'm selling the car now so need to sort the faults, Thanks in advance |
08-26-2015, 02:33 PM | #7 |
175
Rep 1,596
416F is something to do with neutral sensor.
4B2D is "MSR Activation" 4A6E is glow plug on cylinder 1. The first fault will probably be the issue with your start-stop system. no idea what the second one is third one is just a faulty glow plug. |
08-26-2015, 04:34 PM | #8 | |
28
Rep 306
Appreciate the reply! I'll get the neutral sensor looked at tomorrow then and see if it sorts anything!! Thanks |
08-28-2015, 09:47 AM | #9 |
529
Rep 2,503
As far as I know 461F is for your start stop and could be related to:
- Clutch pedal travel switch failure - Battery charge level critical - Voltage Quality Module fuse failure (VQM) -Gear neutral sensor failure - Brake pressure problem If it was fine before you battery problems then the smart money is that it's battery related. What voltage is your battery holding? Have you actually cleared the faults since having a correct battery installed? |
08-30-2015, 04:06 AM | #10 | |
28
Rep 306
I got the neutral sensor checked and the garage fixed it for me and said that was the fault, all reset and ok again now! Thanks for all the replies guys |
01-29-2016, 09:16 PM | #11 |
Rep 22
Auto Start Stop
My car has Auto Start Stop but it never seems to stop when I stop the car and put the handbrake on. I expect the engine to cut out when I put the gear stick in neutral but it dosn't? Why would this be?
01-30-2016, 01:33 AM | #12 |
136
Rep 5,050
There are a lot of parameters that prevent Auto Stop / Start activating, such as engine temp, I think there's a fairly comprehensive list in the handbook, but be grateful because ASS is sooo annoying, I switch it off as soon as I start the car.
01-30-2016, 10:15 AM | #13 |
31
Rep 559
Having the right voltage does not necessarily mean that the stop-start will work. The available amps is also important. If it is a 90amp battery the stop- start requires say 70 amp available to work. Old batteries will show over 12volts but will have low amps available.
01-30-2016, 12:30 PM | #14 |
Rep 22
08-21-2018, 02:35 PM | #15 | |
Rep 2
01-12-2019, 09:17 AM | #16 |
Rep 4
I have the same issue . i have done a scan and i have a problem with my brake vacuum sensor. this is the cause to why my stop start isnt working .
01-12-2019, 01:28 PM | #17 |
Rep 92
There is a fuse or module for stop start which is about £60 from BMW.
A battery change can affect this. I have had to change these on 2 x Lci' models after a battery change (which was not coded to the car). I cant remember what the code was but it came up on the dash with the steering lock warning lamp but was nothing to do with this, it was just the stop start controller. Its shite like this that spoils what is an otherwise good car. |
