Individual Audio/Premium Sound Amp Power wiring
08-21-2015, 09:32 PM | #1 |
128
Rep 525
Hey guys,
Does anyone know how to install the Individual Audio Amplifier? I know the sound output pins but i'm specifically after how to get power to the AMP. I've tried installing it but i can't get the thing to turn on. The amp is slightly different to the logic 7 amp because it has (what i think is) a separate dedicated socket for the power - 2 Pins. Additionally the most fibre optic connection has 4 contact pins as well which i'm not sure whether it needs to be connected to anything. I've searched though wiring diagrams online but they don't show the Individual audio amp. Does anyone have access to a proper wiring diagrams and would be willing to check on this for me? Heres a thread i have on 1addicts that has everything i've tried to accomplish this. http://www.1addicts.com/forums/showthread.php?t=1148763 Thanks to anyone that could help with this. |
12-29-2015, 04:23 AM | #2 | |
20
Rep 105
Update
In order to power up this Amp, needs to bridge the 2 pins (1 and 2) right beside the MOST plug. Pin3 is the ground, pin4 remains unknown. The power on is provided by the MOST and not the pin10 of the Sound Plug, here not needed (as for the pin20 which is ground). If someone can complete ... for fun. Last edited by Pierre26; 12-29-2015 at 04:42 AM.. Reason: pic add |
01-13-2016, 03:03 AM | #3 |
20
Rep 105
Also would add a question about the Power socket housing located at the right side of the pic:
Can someone give the OEM Ref? It is used for Logic7 - TopHiFi amplifiers and can't find it at Realoem or ETK. May be Thecnic can do ... with the rights 2 Pins Thanks. |
01-13-2016, 09:01 AM | #4 |
456
Rep 2,749
that's not true, this amp get main power from 20-pin socket or separate socket.
bridge in MOST socket simply configures to power upper MOST logic board, after that amp is available on MOST network
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
01-13-2016, 10:33 AM | #5 | |
20
Rep 105
The second pic is from another thread (so another Amp from a F31/2011) which seems to have the same Power Plug, and yes the power pins (12v and Ground) are bridged Inside the Amp with the pins number you told. So can you give me at least the power Ref one? Thanks again. |
01-13-2016, 01:06 PM | #6 |
456
Rep 2,749
you do not need additional power plug
you can power this amp from 10/20 pins of the round pin connector OR new power plug
03-03-2016, 12:48 AM | #7 | |
20
Rep 105
I wanted to do this way because of 40-50A on the individual (near 800W) Power Plug Ref is : 6113 6 907 385 and I think that these 2 pins are better than the power one described in the file because they don't have the big size (6,3 mm instead of 10 mm): LSK8 4-6 mm˛ 12521436649 Full info in this *.pdf : https://www.sendspace.com/file/o5wg40 or: https://drive.google.com/file/d/0B8v...ew?usp=sharing Last edited by Pierre26; 03-05-2016 at 04:20 AM.. |
