Enkei Raijin 18x8.5 and 18x9.5 --- What tire size?
08-19-2015, 03:20 PM | #1 |
300
Rep 3,969
Hey Guys,
just picked up these wheels used. The specs are as follows: Fronts: 18x8.5 +38 Rears: 18x9.5 +35 I was thinking about going with Michelin PSS 245/40/18 and 275/35/18 on this stock set-up (not lowered). The other option would be 235/40/18 and 265/35/18. I currently have a 15 mm spacer on the rears with the OEM style 162 wheels. So my other question is can I keep the spacers or would that push the tires out too much and cause rubbing? I am leaning towards taking them out. I understand the PSS run a bit wider than most other tires, so I want to make sure I select the correct tire size. Another HUGE factor for me is rim protection. The PSSs have a small lip on them that protects the rims somewhat from curb rash. I understand that this does not fully protect from curb rash, but it helps. So I was thinking to go with the 275/245 combo since this causes the sidewalls to push out a little more past the rims. Any advice, especially from users who have run similar set-ups, is greatly appreciated!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
08-19-2015, 03:57 PM | #3 |
300
Rep 3,969
No not wanting to alter anything unless absolutely necessary. Why the smaller tires?
08-20-2015, 12:10 PM | #4 |
300
Rep 3,969
Bump, been doing a lot of reading but have not found anyone with a similar set up.
Another thing I would like to discuss is the fitment of 275 wide tires on 9.5 inch wheels. to me it sounds like this would be a near ideal fitment, if not a tad small based on the OEM fitment of 255 wide tires on 8.5 inch rims, which is what I have now on the rears. going from 8.5 inch rims to 9.5 inch rims represents an increase in width of roughly 25 mm. The increase from 255 to 275 is 20 mm. therefore, the 275 mm wide tire on a 9.5 inch wheel is still 5 mm less than the fitment of the 255 mm tire on the 8.5 inch wheel. Therefore I do not see the problem of going for 275 mm wide tires. In fact, a 285 mm wide tire should still fit fine because it is only 5 mm wider fitment then the OEM set up. Am I missing something?
08-20-2015, 03:38 PM | #5 |
BimmerPost Supporting Vendor
1434
Rep 2,650
The ideal tire size would be 235/40/18 front, and 265/35/18 rear. You can certainly run a 245 front tire, but the overall rolling diameter becomes short with a 35 profile, and tall with a 40 profile. For this reason, we recommend a 235/40/18 with a 8.5" wheel. In the rear, the 265/35/18 will fit perfectly without any modifications. You can move up to 275/35/18's, but you may need to roll your rear fenders to prevent rubbing.
Do not base your selection off of the 8.5" wheel with 255's. A 255 tire is quite large for an 8.5" wheel, and not ideal. To have some decent sidewall support, you would want at least a 9" wheel for a 255 tire. - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
08-20-2015, 03:53 PM | #6 | |
300
Rep 3,969
08-20-2015, 06:09 PM | #7 | |
1434
Rep 2,650
- Ryan
08-20-2015, 07:42 PM | #8 | ||
300
Rep 3,969
08-20-2015, 08:22 PM | #9 |
223
Rep 5,120
I had the same size with 19" Hankook v12s 245/35 and 275/30 and et35 in the front . The rear was kind of close without anything done to the fenders. If you have closer to 1.7-2. degrees of camber you shouldnt have problems. I had -1.5 degreees in the rear.
08-21-2015, 12:27 AM | #10 | |
1434
Rep 2,650
- Ryan
08-21-2015, 06:57 AM | #11 |
300
Rep 3,969
So I have decided to go with 245/35/18 fronts and 275/35/18 rears. Any objections? Here is the calculation & visualization compared to OEM.
08-21-2015, 08:11 AM | #13 |
300
Rep 3,969
What are your offsets?
08-27-2015, 11:51 AM | #14 | |
226
Rep 553
This is with it jacked up on the other side to show the clearance. |
08-27-2015, 04:51 PM | #16 |
300
Rep 3,969
Thanks guys. Got everything installed. Turns out the 275/35/18 tire does not give much rim protection at all. Perhaps next time I'll go with 285/30/18 size.
Looks good, and tires ride awesome. Now of course it is screaming to get lowered! Am I correct in the assumption that if I do not get any rubbing now, I should not get any rubbing with a lowered suspension?
08-27-2015, 07:17 PM | #17 |
226
Rep 553
Not necessarily, but I know you won't with that offset. BTW I checked the inside clearance on mine and there's plenty of room.
Car looks great! Last edited by CoffeeBean; 08-27-2015 at 07:23 PM.. |
08-27-2015, 10:03 PM | #18 | ||
671
Rep 2,219
08-30-2015, 11:35 PM | #19 | |
60
Rep 211
09-27-2015, 05:56 PM | #20 | |
31
Rep 122
Best bet for rears would be to drop to 245/35/18 or bump to 255/40/18 For my winters I have them set up on my stock BMW rims and they are 225/40/18 front and 255/35/18. They look great and work awesome in the snow, definitely a little harder to find the rear tires tho. Check out Pirelli Sottozero 3 if your ditching the runflats or Sottozero 2 if you have runflats. The Sottozero 3 preforms much better in snow I find so I bit the bullet this year and purchased the supersaver spare tire kit from the dealership for some added piece of mind on the road. (don't let a tire retailer tell you they don't exist because they do and find a better retailer that's willing to order them) |
09-27-2015, 09:51 PM | #21 | ||
671
Rep 2,219
10-06-2015, 09:08 PM | #22 | |
187
Rep 113
--Sebis
