08-19-2015, 01:22 PM | #1 |
58
Rep 112
DIY: Rear sway bar?
Does anybody have a DIY for a rear sway bar for m235 or any instructions/tips/installation time??
Thanks guys |
08-19-2015, 01:29 PM | #2 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
The installation time has been quoted as 6+ hours because you have to drop the rear sub-frame to get at the sway bar. That time is also probably with the correct facilities (i.e. lift), I'd imagine it would otherwise be worse.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
08-20-2015, 09:36 PM | #3 |
125
Rep 356
It can be done in less than 6 hours for sure. You'll need a trans jack preferably and a lift. You can lower the rear subframe just enough to get the old bar out and new one in.
You're still looking at 3-ish hours though. |
08-21-2015, 01:05 PM | #4 |
450
Rep 845
It's harder than you think. If you are in the business of being careful, it takes 5-6 hours for a good independent shop that doesn't do this on a regular basis. The front sway is even harder, as you need to basically un-mount the engine, put it on a lift, drop the subframe, then do the sway bar install.
Not recommended unless you track the car. It's too much of a pain in the ass.
08-21-2015, 02:04 PM | #5 |
463
Rep 957
As someone who did it himself, I can say I am glad my neighbors shop has a lift. I have a small "Track Jack" Jack system. I could have maybe done it with that but would have been a mess.
So, If you are comfortable messing around with sub frame, drive train, drive shaft, exhaust, suspension than yes. Without a lift, you have to do all that in 24" or so of space. Oh by the way, front is twice as hard. |
01-17-2016, 12:31 AM | #6 |
37
Rep 233
Is the rear sway bar worth upgrading by itself for those who track regularly? I'll be installing a LSD to the car, should I be looking at changing the sway bar as well?
