335i performance exhaust clamp size
08-16-2015, 03:51 PM | #1 |
Rep 20
Hi guys,
Hopefully someone will be able to help... Can someone please tell me the part number of the outer clamps for the 335i bmw performance exhaust? It is the larger of the two sizes and they connect the two back boxes to the existing exhaust system. Thanks George |
08-17-2015, 02:57 AM | #2 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
RealOEM lists two part numbers for the 335i performance exhaust clamps:
18307560779 - 60mm diameter (two required) 18307560778 - 55mm diameter (one required). Hope that helps...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
zero2sixtyZ951.00 |
