08-14-2015, 06:32 PM | #1 |
Rep 21
MPE Back fires??
I have a 2015 F33 with MPPK and MPE with about 2400 miles on it now. The last couple of days I have noticed when coming up at highway speeds ( 55 mph) to a stop sign and braking hard (throttle closed) to a stop, that I get the normal rumbles as it downshifts, but the last one or two downshifts as I stop, I get a series of actual crackling sounds like a mild series of back fires. I like the rumbles, but not the back fires, doesn't sound right coming from a sophisticated, expensive car.... Anybody else getting this ?? I know some of the rumbles are actually coming from the sound system, but with the top down, I am pretty sure the cracking sound is coming from the actual exhaust itself.
08-14-2015, 06:59 PM | #2 | |
428
Rep 1,108
08-15-2015, 09:41 AM | #6 |
114
Rep 208
I get this too! love it most of the time but sometimes its.. kind of a bit much. Easy solution is to use normal or eco pro… otherwise Ive noticed with mine it happens when i shift down to around 2k rpm it does the backfire so if i want to avoid it i shift down earlier. oddly enough higher revs seems to produce the burble and lower revs the backfire…
just my observations anyways… not sure if im right or not |
08-15-2015, 12:16 PM | #7 | |
177
Rep 482
snap....crackle....POP! |
08-16-2015, 05:08 PM | #8 |
Rep 21
I got this option (MPE) to get a more aggressive sound and some "burble" on downshifts. I read many descriptions of what to expect, but don't recall ever having anyone mention actual back fires.....not sure I would have got it if I would have known. Just information for anyone out there considering getting this option on what to expect.
08-17-2015, 05:06 AM | #10 |
41
Rep 158
I personally enjoy the attention. It definitely backfires while slowing down. Drives the wife crazy.
435i Imperial Blue 2015 /Luxury/Tech /Premium/MPPK/Dinan Stage 1/Dinan polished tip exhaust/HK/Driver Assist/Driver plus/M Sport Brakes/Side Cameras/Saddle Brown Dakota/Escort Max Radar
08-17-2015, 01:08 PM | #11 |
17
Rep 50
It is also noticeably more aggressive when driving in manual mode (8AT) and shifting down from ~2k rpm when slowing down. Quite a loud 'crack'.
If it gets tiresome just knock it into comfort, only get minor pops and crackles then :-D |
08-17-2015, 04:27 PM | #12 | |
30
Rep 254
Drives: E30 M3 & 325ic-F30 335i Xdrive
There is definitely something wrong with your MPE, you should trade it in for a MES (MEISTERSCHAFT EXHAUST SYSTEMS) .
08-17-2015, 05:41 PM | #13 |
55
Rep 681
The problem is the inside sound (very low, for my car without ASD), not the outside sound that is pretty good with MPPK+MPE.
But I think you aren't used to true sport exhaust sound, that are much louder
BMW M3 G80 Isle of Man
