installing a 15" sub in the trunk
08-14-2015, 04:33 PM | #1 |
60
Rep 309
hi there ive been reading the sticky but im still a little bit confused. I want to install an apline type r 15" in my 2007 bmw 328xi.
here is what i have http://www.crutchfield.com/S-wKs1SnA...SWR-1522D.html http://www.amazon.com/gp/product/B00...ilpage_o02_s00 http://www.amazon.com/gp/product/B00...ilpage_o01_s00 im reading something about technic harness? am i going to need that? or should i just get a high to low |
08-14-2015, 06:52 PM | #2 |
300
Rep 3,969
Some more reading. You are getting warmer, but first understand the advantages/disadvantages of the type of sub set-up you're planning on installing.
http://www.e90post.com/forums/showpo...2&postcount=66
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
08-15-2015, 12:48 AM | #3 | |
60
Rep 309
like the HiFi harness w/XD kit OEM 12V Battery slot connector single or double oem connector HiFi Harness which one do i get if the xd kit do i get single or double? http://www.technicpnp.com/product_pu...E90-92-93.html |
08-15-2015, 08:05 AM | #4 |
300
Rep 3,969
I thought at one time he made a subwoofer add on harness for HiFi but I'm not sure, so contact him. In the worst case you'll have to tap the OEM speaker wires and use a high quality line output converter.
08-15-2015, 11:08 AM | #5 |
300
Rep 3,969
Understand that the trunk is a bass trap. If you have a ski-pass or fold down seat, it will help a lot, if you can keep it open. If not, most of the energy from the sub will stay in the trunk and convert to vibrations/rattles of the trunk panels. Making the sub and amp bigger, to get more volume in the cabin, will just increase the rattles.
If you want it to sound good without rattles, you need to do more than trowing a box in the trunk. Read the link I gave you if you haven't done so already.
08-17-2015, 10:29 AM | #6 |
379
Rep 2,365
Drives: 2007 E90 323i (Cdn)
Definitely don't want to go against what Kaigoss is saying, but many here do say that the corner load enclosures sound very good even with a sealed trunk.
I have a 10" in a custom box under the trunk floor (inside that storage compartment and it also sounds great. I don't have fold down seats or a ski pass. Finally, if you're set on using a 15", go with an IB setup, assuming the woofer you already have is suitable for that.
08-19-2015, 03:30 PM | #7 | |
300
Rep 3,969
08-21-2015, 09:20 AM | #9 | |
2134
Rep 3,554
Its all in the enclosure build and the type of sub used. A pure sq sub isnt going to get loud. |
