EGR Cooler - Keep breaking it.
08-12-2015, 03:48 AM | #1 |
38
Rep 243
I've got a mapped E90 320d (m47) running at 210bhp and I keep blowing the EGR cooler on it........happens when I've been giving it some welly it seems.
The flexi copper coloured pipe keeps splitting, releasing exhaust gasses into the cabin. I replaced my old one with a part worn and it's failed already. BMW want £300 for a new one and i'll pay it if the problem goes away but is this related to the map and will the new one blow again? |
08-12-2015, 08:09 AM | #4 |
46
Rep 891
The fact that your blowing out the flexi bit, would presumably mean that either the cooler itself or your EGR valve itself is blocked, and that flexi bit is just the weak point. (have you fitted a blank?)
I removed mine (did you send me a question on ebay about the one I'm selling?) you have to block the exhaust manifold, get a new "throttle body" and block 2 coolant pipes, one 15mm and one 20mm. I used some cut down bolts with jubilee clips. thread here (pictures 8 & 9): http://www.e90post.com/forums/showthread.php?t=1147631 |
08-12-2015, 08:55 AM | #5 |
175
Rep 1,596
chrissy:
If the EGR is mapped out, the cooler is redundant. But to remove it you need to blank off the connections at each end, and also the coolant lines. I think the coolant blanks you need are 18mm. The exhaust manifold blank can be purchased on ebay, as can a replacement for the EGR valve on the intake. |
08-12-2015, 03:31 PM | #7 |
175
Rep 1,596
the cooler doesnt need to be there for the coolant to circulate properly.
Its T'd off the main coolant lines at either side, so removing it doesnt affect the coolant flow. It also lets you get rid of the EGR thermostat, save you replacing it when it goes faulty! |
08-13-2015, 03:06 AM | #8 |
38
Rep 243
Icekube Yes that was me
I couldn't understand the need for the EGR cooler to still be there. Right so......... I need an EGR delete basically for the intake? Yours looks good quality, have you got a link for it? What did you do with your wire to it, block it off? Any idea what exact coolant blanks I need!? Glad you have all contributed to this, I was about to order a brand new one from BMW. |
08-13-2015, 03:34 AM | #9 |
175
Rep 1,596
What exact engine do you have?
Craigs is an Allard EGR delete, designed for an E46. It fits fine on the E90 but doesnt have the quick release fitting on the end. If you wanted to use that one, you'd need to swap out the hose from the intercooler that attaches to it. It'll also only fit if you DONT have the electronic throttle body in front of the EGR valve, i dont think M47's do, but if that is there, you need a different one which they also sell. http://www.allardaluminiumproducts.c...elete-kit.html the exhaust manifold blank came from ebay: http://www.ebay.co.uk/itm/53-8-mm-EG...item2a31511cc9 Then for the coolant hoses, we just cut the old pipes and jubilee clipped in some bolts to block it off, but a neater job would be to use two of these in 18mm: http://www.ebay.co.uk/itm/Auto-Silic...item43ceea0296 |
08-13-2015, 03:58 AM | #10 | |
38
Rep 243
Been looking at the EGR deletes and they mention an anti shudder valve? Mine has a clip on intake pipe that then connects to the EGR. Does that mean I need an older e46 one then? |
08-13-2015, 04:30 AM | #11 |
38
Rep 243
08-13-2015, 05:30 AM | #13 |
38
Rep 686
hmm ive just started getting exhuast fumes in the cabin after a blast of the beans!! thought it could be the exhaust blowing at the flexi or CAT but could well be the same issue.
Not had chance to inspect but if it is the same think i may look at EGR delete. Question though: mine is also re-mapped if i EGR delete will i have to get it re-re-mapped? or is there away of cheating the system? Could you just blank the EGR at the Exhaust end? or will that still throw warnings and errors? |
08-13-2015, 06:25 AM | #14 | |
38
Rep 243
Depends if you can live with it or not. |
08-13-2015, 07:06 AM | #15 |
38
Rep 686
thanks, just been reading through this thread http://www.e90post.com/forums/showth...egr+off&page=8
which outlines the same. However some have said they get codes but no EML? |
08-13-2015, 08:07 AM | #16 | |
38
Rep 243
08-13-2015, 08:24 AM | #17 |
38
Rep 686
to be honest id be surprised if it didn't throw an EML. but if my EGR cooler is blowing like yours blanking it off is a cheap temporay fix. Id rather have a EML that i know the reason for than gas myself out with diesel exhaust fumes!!
Looks like the kit the guys are using in the states has two blanks. one for the exhaust end and one at the EGR/Throttle end. Cant seem to find anything like that on Ebay. |
08-13-2015, 08:26 AM | #18 |
175
Rep 1,596
chrissy: You have the electronic throttle in front of the EGR unit, so you need the other one that allard sell with a bolted flange on the front:
http://www.allardaluminiumproducts.c...gr-delete.html If your EML came on when you removed that small pipe (assuming you blocked the pipe and didnt cause a vacuum leak) then it probably means the EGR is not disabled in your tune. You'll need to get the EGR disabled in your tune to get the light off and properly delete the EGR system. You can still go ahead with the delete, but the EML light will stay on until you get it properly removed from the tune. |
08-13-2015, 10:14 AM | #19 | |
38
Rep 243
So basically I unbolt the throttle body and bolt it onto the new delete and then connect the intercooler pipe up? |
08-13-2015, 10:20 AM | #20 | |
38
Rep 243
I've just found another photo of an E90 320d's engine bay and it looks identical to mine That one doesn't have the electronic throttle body on it does it? |
08-13-2015, 10:47 AM | #21 | |
46
Rep 891
mine certainly didn't have the throttle body like yours has, but also that engine bay just looks a bit different to the E90, the air intake for instance, and the brake fluid reservoir looks different, also the pipes in the top right look different too? |
