08-07-2015, 12:24 AM | #1 |
15
Rep 115
Running in
What's peoples way of running the M5 in?
I've read debates for most other cars I've looked at over the years and they say drive hard from day one or you'll get a "slow" one. But that is for lower performance cars, I'd imagine this one takes a bit more care ?? |
08-07-2015, 03:15 AM | #2 |
Rep 40
I went by the book, took my time and drove normally. Any chance I could to do a longer trip I would load the miles on.
2014 F10 M5 2012 Aston Martin Vantage 2010 Audi S5 |
08-07-2015, 04:45 AM | #3 |
15
Rep 115
I remember a car I had years ago and was to run it in short journeys so more revs and gears were used as allowed to 4x300 mile journeys where the car is ticking over 90% of the time....
Also don't go above 106mph?? |
08-07-2015, 05:53 AM | #4 |
13
Rep 312
from what i read, and what i intend to follow, is first 40-50 miles vary revs and do engine braking. this helps bed the pistons in. from that point then follow the manual.
08-11-2015, 02:04 AM | #5 |
412
Rep 1,157
For me, I waited for the engine to get some temperature on the gauge and then drove it as I normally would.
I picked mine up in December though so not the best time of year to try to put too much power down. I think as long as you try not to keep the revs constant for too long and try to avoid the red line you'll be fine. Drive it and enjoy it
Current: recovering slowly
Previous: F31 340i Ruby Red IIM5 Singapore Grey, F30 335d Moonstone, F30 320d Tanzanite Blue |
08-11-2015, 02:55 AM | #6 |
15
Rep 115
Thanks, so there's no physical limit on revs or speed set before running in. Read a debate that the power is dulled down until the running in service is completed... Can't see that?!
08-11-2015, 04:38 AM | #8 | |
412
Rep 1,157
The running in service is just a change of fluids as far as I was told. Nothing is switched to turn on more power but the drive home should be via the scenic route just to make sure
