F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55 JB4 jerky when startup
Extreme Powerhouse
      08-03-2015, 08:19 PM   #1
Tuned435i
Tuned435i's Avatar
75
Drives: 2017 M2 6spd
I recently installed my burger tuning JB4 along with a injen CAI and a RaceWerks charge pipe. When I have the Jb4 turned on the car is very jerky when idling, especially pulling out of the drive way. When I turn off the JB4 it runs perfectly fine. I haven't had any other problem with the JB4 and it definetely increase the performance. Is there a way to stop the jerkiness by putting on different parts or something?
      09-04-2015, 12:42 PM   #2
Straight6Driver
38
Drives: F30 335i
Bump.
Similar issue here. JB4 with charge pipe. Jerky lower rpm when the car is cold. Idling is fine though.
      09-04-2015, 01:08 PM   #3
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
24201
Drives: 07-335/12-328/18-M4/21-M4CP
Double check installation. If everything looks good contact jon at burgertuning.com
https://x-ph.com/sale/
Phone number 702-494-9435
      09-05-2015, 07:19 AM   #4
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
515
Drives: 582whp/596wtq '13 335i
Check installation, codes, and Take a log and send it to john or terry.
      09-05-2015, 07:27 AM   #5
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Originally Posted by Straight6Driver View Post
Bump.
Similar issue here, but when im cruising in low speeds and low RPM like 1300 RPM my car feels like its fighting itself and jerking like feeling. But when in higher RPM and speed it is fine.
FBO-PS1 and stuff
      09-05-2015, 01:51 PM   #6
Straight6Driver
38
Drives: F30 335i
Does it go away once the car warms up?
Do you get "drivetrain malfunction" fault code at all?
      09-05-2015, 02:18 PM   #7
Jadar
Dejan
Jadar's Avatar
Serbia
1753
No codes and it actually happens only when the car is WARM. Not noticing it when the car is cold. It's very slight hesitation. It's not consistent.
FBO-PS1 and stuff
      09-06-2015, 12:34 AM   #8
Straight6Driver
38
Drives: F30 335i
Weird. Mine happens more often when cold and I'd get a drivetrain malfunction full engine power not available warning.
      09-06-2015, 06:25 AM   #9
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Damn that sucks. Every time? This is why I'm jumping into a flash tune group buy. I don't want this choppy inconstant feeling...
Hope you get it resolved..
FBO-PS1 and stuff
      09-06-2015, 07:08 AM   #10
Mike@N54Tuning.com
4918
Drives: 2007 335i, 2015 M3
There are lots of different problems that can come up which will result in a rough idle. Some are caused by intakes or downpipes, others by JB4 setting, yet others by things unrelated to tuning like vacuum leaks or MAF sensors coated in filter oil.
If you are able to get a CEL out of it you're way ahead of the game. Read the code and then find someone who knows what the code means to help you solve it. If you have a BMS product on the car you can post the code and details in their support forum for professional help.
If you are not able to get a CEL then its much more difficult to determine what is wrong. A datalog is normally a good first step though.
Mike
      09-09-2015, 06:55 PM   #11
wanghao
Drives: 2014 F30 335i
Same issue here, engine just got low rpm when I cold start it, and then it jut goes off. It doesn't happen everyday on my car though. ( I got JB4, ER down-pipe, Akra exhaust, and AFE intake)
      09-09-2015, 08:12 PM   #12
mike@x-ph.com
24201
I would start by datalogging if possible
If not remove the intake
      09-10-2015, 09:10 AM   #13
Straight6Driver
38
Drives: F30 335i
Yes almost every time. Yet to find a solution.
      09-10-2015, 09:11 AM   #14
Straight6Driver
38
Drives: F30 335i
I'm on stock intake, yet it does the same thing.
      09-10-2015, 09:11 AM   #15
eric@helix
eric@helix's Avatar
210
Drives: 01 M Coupe, 08 135i, '12 328i
Check the installation/fitment of the charge pipe.
      09-10-2015, 09:12 AM   #16
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Sorry to hear. May want to think about removal.
It annoys me and I don't even have the big problems you have. I'm resolving it via ENZO flash tune .
I'm not screwing with this anymore.
Good luck.
FBO-PS1 and stuff
      09-10-2015, 09:20 AM   #17
Straight6Driver
38
Drives: F30 335i
Mike
I did get a CEL eventually:
122108 Blow-off valve: Jammed closed
108A10 charge air temperature sensor, electrical: signal not plausible
120408 charging pressure control, deactivation: pressure build up blocked
180001 catalytic converter: efficiency below limit value
These codes came up during the CEL.
This was one week ago. I managed to track down a GFB DV replacement assuming the BOV/DV is faulty. (The GFB DV replaces the diaphragm of the OE DV with a piston type internals).
GFB DV installed today. Now I'm still getting the "drivetrain malfunction" warnings here and there, although they're not as frequent as before the DV replacement.
Going to the workshop tomorrow again to scan for codes.
      09-10-2015, 09:22 AM   #18
Straight6Driver
38
Drives: F30 335i
Good luck.
Let us know how the flash tune goes. I have access to cobb over here if all else fails with JB4.
      09-10-2015, 09:25 AM   #19
Straight6Driver
38
Drives: F30 335i
Care to explain a bit more? I did ask the shop to check the charge pipe install (but TBH I'm not certain if they ever did).
      09-10-2015, 09:48 AM   #20
Mike@N54Tuning.com
4918
Was going to suggest the DV replacement so glad you did that. Lets see what the new codes are.
Mike
      09-10-2015, 10:08 AM   #21
mike@x-ph.com
24201
Good luck.
I would not get a flash tune before i am sure this issue is caused by the JB4 and so far no indication whatsoever points to the JB4.
If you have tried everything and you still cant find a solution, i recommend you contact Burger Tuning technical support
      09-10-2015, 01:57 PM   #22
shivaswrath
shivaswrath's Avatar
649
Drives: 2012 335i
Fuel pump?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
f30post
