just lovely
08-03-2015, 12:54 AM | #1 |
DIYER
614
Rep 5,521
just lovely
Just lovely
Counted threads as I do after every alignment and they are dead even and exactly the same day of alignment. Camber has not changed either. Alignment was "0" total toe and -2.0 camber. Guaranteed it never was, last alignment was 4 months ago and have not hit anything. You can clearly see these front tires had a lot of life but now are garbage. I am sure alignment place will say camber did it.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
08-03-2015, 09:19 AM | #2 |
Combined Applications Group
1059
Rep 680
When setting front 0 toe static it will result in a (toe out ) negative toe while under power and braking, you may want to adjust it slight (toe in) positive to account for this.
It is also possible your bushings may be a bit worn out allowing for excessive negative toe under power and braking resulting in the above. Is this the case for both sides in the front? |
08-03-2015, 12:39 PM | #3 | |
DIYER
614
Rep 5,521
08-04-2015, 09:28 AM | #4 |
1059
Rep 680
08-04-2015, 11:38 AM | #5 |
DIYER
614
Rep 5,521
you may have a point here. You think when going around corner it is pushing toe out? So in theory asking for a bit of "toe in" will result in 0 toe from flexing from acceleration and going around corners?
I used to have alignment set to .03-.06 per side for a "total toe" of .06-.012
08-04-2015, 12:57 PM | #6 |
1059
Rep 680
Yeah I think that is exaclty what is happening, the stock bushings allow for some small play so setting toe to 0 will essentially be slight toe out while driving.
In a corner you are essentially under steering the front, either slightly or a lot, only you can know that, and the front insides, of the inside wheel are scrubbing hard, also due to camber and you can end up with what you have above. Also in a straight line, under power and under braking your front wheels open up like she wants it if you close them up a bit in static alignment you can essentially have a 0 toe under power/braking but its hard to fully judge the effect of toe adjustment in corers as it varies greatly with the steering angle and the type of cornering you do(slow/fast). One more thing is tire shapes, some are more rounded, some more squared off , for same size/ratio, so it will take some time to fully optimize a good alignment. there will always be a trade off But it sux to wake up to what you posted above, good tires with destroyed insides... happened to me many times |
08-04-2015, 01:00 PM | #7 | |
215
Rep 1,818
closer to .5" and I'd believe it, but not at such low levels |
08-04-2015, 01:04 PM | #8 |
58
Rep 494
I have the same thing, and yeah alignment was done did not hit any major potholes, suspension was checked and seems solid. It is just something about these cars which destroy front tires. Let me know if you figure it out.
08-04-2015, 01:07 PM | #9 | |
215
Rep 1,818
inside wear is from aggressive toe and camber |
08-04-2015, 02:22 PM | #10 | |
1059
Rep 680
I can under steer with 0 contact on the outside part of the front tire if I have some ricer style camber. Under steer means you are not following the direction of the tires 100%, which is almost always the case unless you are going slow. When you are in a corner you always under steering to some extent, pushing the front, your car never follows the path of the tires unless you are turning at 30-40 km/h and even then While turning you put greater pressure on the outside of the outside tire and on the inside of the inside tire, unless your car is specifically aligned for that particulate corner at that particular speed in which case you will have even contact on outside tire while scrubbing only the inside of the inside tire, which should almost be off the ground But talking about street cars only, it seems that for the situation above there is a slight toe/camber out of spec either static or in motion |
08-23-2015, 02:20 PM | #12 |
DIYER
614
Rep 5,521
Oh yes, the alignment place I went to must have been on every drug known to man!
My front toe was Left front: 0.38 Right front: -0.12 I asked for "0" toe or slightly tied in!
