07-28-2015, 08:22 PM | #1 |
29
Rep 219
Drives: 14 BMW 335xi M-Sport EBII
No Boost
I have a 2014 F30/N55 and in the last day or so I have no boost and I throw a "low pressure" code as well.
I have a aftermarket intercooler and when ahead and double check the connections from the intercooler on both sides as well as the charge pipe into the engine and all seem well. As far as I can tell no welds have failed on the charge pipe. Is there a good easy way to check for the boost leak? Anywhere else i should check for a loose connection? I know the charge pipes can be an issue on these cars and I wanted to swap it out with the intercooler, but x-drive charge pipes weren't available. |
07-28-2015, 09:20 PM | #3 |
BimmerPost Supporting Vendor
24199
Rep 190,807
Check intercooler connections, charge pipe and lines. You also want to check the boost silenoid
07-29-2015, 08:46 AM | #4 | |
4918
Rep 115,980
Mike |
08-02-2015, 11:55 AM | #5 | |
29
Rep 219
With the stock intercooler in the car I will probably take it to the dealership for now and see if they can figure it out. |
08-12-2015, 10:12 PM | #7 | |
55
Rep 467
