2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Why NOT 275-35-20 / 245-40-20 ON 550
      07-27-2015, 10:17 AM   #1
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
Please delete
      08-03-2015, 05:30 PM   #2
ndinh
161
Drives: 640i GC, X5
I just installed a set of 245/40/20 and 275/35/20 on my wife's F10 because she wasn't happy with the ride quality of the standard 35 and 30 aspect ratio. I was worried about rubbing but it worked out great. Her car now rides as smooth as my F07. The car gained about 1" in height but it's not very noticeable and the tires fill the wheel well much better. I recalled there was another F10 owner that put some 20" Alpina wheels from a 7-series and it fit fine. The only thing I did notice was it took a little more for the car to accelerate from a stop light due to the larger OD but since you have a 550, you probably won't notice.
      08-04-2015, 10:47 AM   #3
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
ok thats good I was actually wanting to do 245-40-20 and 285-35-20 i wonder how it would look
      08-04-2015, 01:43 PM   #4
M5Beast_NYC
158
Drives: 15 M5
Are you lowered? I think stock height this is a non issue.. but if you are lowered, this could cause problem.
      08-04-2015, 07:04 PM   #5
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
I'm not lowered at the moment and probably won't be be for a while . I have a line on 4 like new tires in that sizr
      01-14-2016, 11:01 AM   #6
anthonyg2003
Drives: 2012 ActiveHybrid 5
@ndinh - my 2012 ActiveHybrid 5 came with dealer option 20" wheels, which I believe are 8.5 Front, 9 Rear (I don't know the offsets). I, too, am wanting to install 245/40/20 and 275/35/20 on the car. The AH5 is supposed to be identical to the 535i.
Right now the car has 245/35/20 up front and it looks pretty close to the spring already, so I'm worried it'll rub there.
You said you installed these tires on your F10, but is yours a 550 or 535? I don't know if there is any difference in the wheel wells or front suspension between the two, so I'm hoping your's is a 535..
      01-14-2016, 12:09 PM   #7
ndinh
161
Drives: 640i GC, X5
528,535,550,AH5 will all be the same (only 4WD models will be different). Your front wheel offset is probably high (closer to the spring side). If your car isn't lowered and it looks like your front tires are inside your fender a bit (looking from front or rear of vehicle), then you can definitely go with the 245/40 + 275/35 setup. You can buy a set of spacers for the front. I've used 245/40 + 275/35 without rubbing at all. It's close but never touches the spring. Now I'm using 255/35 front + 275/35 rear. That's your other option because with the 255/35, your OD is 27" compared to 245/40 which is 27.8". Either way, these options will give you a more comfortable ride than the recommended 35 ff/30 rr setup.
5post
