07-27-2015, 05:58 AM | #1 |
421
Rep 508
Can JB4 be connected as a JB Stage1?
Hey Guys
im thinking about buying a JB4 but my car is relatively new and i was thinking to just buy a stage 1 first, but then i got thinking whether i could by the JB4 and just connect the same wires as the Stage 1. Will this essentially work the same way as a Stage 1, and then when i am comfortable to mod further, i can then add the additional connections required for the full JB4? if so then it makes sense to buy a JB4 from now... Thanks in advance
2023 G80 M3
www.instagram.com/modern.classica |
07-27-2015, 09:43 AM | #3 | |
BimmerPost Supporting Vendor
4918
Rep 115,980
Mike |
07-27-2015, 10:54 AM | #4 |
175
Rep 514
Not on the PWG..... I did it last week and kept getting drivetrain output limited. I wonder if the EWG is different.
2022 BMW M340 X-Drive
2020 BMW X3 30i M-Package (retired) 2018 BMW 440i X-Drive Gran Coupe l Premium Enhanced Package l M-Performance Package + M-Performance Pack 2 (retired) 2013 BMW 335i X-Drive (retired) |
07-27-2015, 11:19 AM | #5 | |
177
Rep 482
Otherwise order the JB stage 1 where you just cross over a couple plugs and dont tap into the canbus wires.. If you go the JB4 route you MUST MUST MUST connect the canbus wires for the unit to work properly. Also connect the FF harness to monitor what your fuel is upto. Its a simple extra 30 second task that adds extra monitoring. Tech questions like this should be directed to N54tech.com for responses from the manufacturer. |
07-27-2015, 12:57 PM | #6 | |
4918
Rep 115,980
Mike |
07-27-2015, 01:16 PM | #7 |
24199
Rep 190,807
You should be able to connect it as a JB stage 1.
I have seen guys do it with the M3/M4 which is a similar board
07-27-2015, 04:43 PM | #8 |
421
Rep 508
Thanks everyone. Seems like JB4 is the way to go for future proofing.
So what is it that makes the JB4 smoother in power delivery than the stage 1? is it those extra canbus connections?
2023 G80 M3
07-27-2015, 05:42 PM | #9 | |
24199
Rep 190,807
the extra canbus connections gives you more features and allows the JB4 to have full control
07-27-2015, 07:38 PM | #11 | |
4918
Rep 115,980
The power delivery and tuning differ between the stage1 and the full JB4 in terms of the fact that the JB4 has full CAN access to all the engine parameters, including cold start safety, etc. Its subtle but there is a difference in terms of drivability. The JB4 n55 uses CANbus data on map 1 to give a smoother pedal to boost mapping as one example of the differences. Absolute power is not much different. Mike Last edited by Mike@N54Tuning.com; 07-27-2015 at 07:45 PM.. |
07-27-2015, 07:39 PM | #12 |
4918
Rep 115,980
07-28-2015, 05:23 AM | #13 |
421
Rep 508
yep mine is a 2015 so definately EWG
2023 G80 M3
07-28-2015, 10:24 AM | #14 | |
24199
Rep 190,807
08-05-2015, 11:26 AM | #16 |
BMW Fanatic
331
Rep 1,076
So conclusion is, with EWG JB4, you don't have to splice any wires? The only reason I'm asking is because the dealership here would try to void your warranty if you put a sticker on your windshield claiming it would ruin aerodynamics.... Anyways, A local tune shop here is claiming same output and operation without any splicing involved, which leaves me stuck between 2 options (Leaning more to JB4 though).
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
08-05-2015, 07:30 PM | #17 | |
24199
Rep 190,807
If you use the OBD cables, no wire splicing is needed. What tune is the other shop using? I am currently in Europe but will be in Lebanon next week
08-05-2015, 08:55 PM | #18 |
Pace Car Driver
1548
Rep 3,164
JB4, the OBD2 CAN connection and the proper OBD2 software is the absolute best thing since sliced bread.
It literally took me 40 minutes to reinstall my tune after a dealer visit. |
08-06-2015, 12:10 PM | #19 |
BMW Fanatic
331
Rep 1,076
Piggyback, his name is Gilbert. Check his instagram out; very talented guy, but would rather stick to something more mainstream. Got an M6 to run 800bhp or something very close to that. Instagram: Protuning_lb
08-06-2015, 12:17 PM | #20 | |
BMW Fanatic
331
Rep 1,076
Edit: Never mind, found some installation notes, connect OBD2 and then route wires to engine bay, but then what? These look spliced wires to me. http://www.n54tech.com/forums/showthread.php?t=30750
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 Last edited by 963mw; 08-06-2015 at 12:25 PM.. |
08-06-2015, 01:37 PM | #21 | |
Pace Car Driver
1548
Rep 3,164
