How much to expect from adding tweeters (base stereo)
07-15-2015, 03:40 PM | #1 |
Rep 44
Hi,
I've been an avid lurker for sometime but only just signed up. Since getting my 320D Touring (10.2010, MY2011) I've been slightly annoyed with the dull sound (like so many others) - so I have read a fairly substantial number of posts here to learn a bit about what the options are I have base stereo, Professional Nav (CIC). While I am intrigued by the many impressive upgrades people have done, I also recognize that I am a complete beginner when it comes to wiring and car audio. I am by no means an audiophile but more a casual listener - so I was looking to start by upgrading to actually having tweeters. I have the PNs for sails with grilles (the 201 and 202s), foam (though I plan on skimping on that and reuse what is in there already as has been advised in several threads). I am however unsure which tweeter to get - there's two different ones. http://bmwfans.info/parts-catalog/E9...ker/#9142512_1 65139217909 Harman Kardon tweeter 65136964012 Hifi Tweeter Incidentally, if I were to progress after this I would likely opt for something like the MB200.3 package, an MB Nano amplifier and a PnP harness from Technic, meaning that I would lose the OEM tweeters again. Any advice from someone who has heard these tweeters in real life? Is there something to be said for buying used so they don't need breaking in - or does that not apply to tweeters? Cheers, H. |
07-15-2015, 03:46 PM | #2 |
461
Rep 2,757
consider genuine bmw alpine kit
it will provide tweeters, upgraded mids and simple amplifier with plug and play upgrade for stereo (base)
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
07-15-2015, 05:57 PM | #4 |
Rep 44
07-16-2015, 02:45 AM | #6 |
台灣人
36
Rep 386
I have base audio, and I just added HIFI tweeters ONLY recently and it brings up upper frequencies of course. While the HU is heavily eq on base audio, it actually makes the high pitch sound too much so I have to lower down treble setting a little bit. Overall is good upgrade with small amount of money (I got both trims and tweeters from ebay for cheap).
I will do alpine kit next month and see how it goes. |
07-18-2015, 10:08 AM | #7 |
69
Rep 994
EQ on your head unit is shaped like a smile (boosted bass, no midrange, and boosted highs due to not having tweeters). you'd need to parallel the new tweeters off the midrange, and add a capacitor for a high pass filter. doing that brings down the load the amp in the head unit sees, which isn't good. i would imagine that the highs would actually be too high. your best bet is to re-code to HiFi and add an amp, then do your speaker upgrades. if you don't, you'd need to tap factory speaker level signals, input them to a DSP, flatten out the EQ and then output that to a new amp (or use a Helix PP82 which is a DSP and 8 channel amp in a package size that fits where the factory amp would be in the driver's side quarter panel.
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
07-19-2015, 12:18 PM | #8 |
382
Rep 2,366
Drives: 2007 E90 323i (Cdn)
Adding tweeters alone can be done but you'll want capacitors or a crossover to high pass them for treble only and protect the tweeters.
A) I suggest at LEAST getting a mid/tweeter component set. Will sound much better and easy to install since you'd already have the door card removed for the tweeter. B) you could then manually turn down the treble to balance the factory EQ, but I'd strongly suggest you recode to hifi and install an amp. This will make all the other speakers sound better too, and make future upgrades (under seat woofers, trunk sub) that much easier down the line Good luck.
07-22-2015, 08:03 PM | #9 |
Rep 44
All, thanks for all the responses!
Considering the input, the most sensible route seems the Alpine kit. Favourable feedback on sound quality if HU is recoded to Hifi, delivered with harness and a lot of guides available on forums so that even a newbie like me should be able to pull it off if carefully planned. I read a thread by makkan where he suggested that the underseat subs should be replaced with L7 subs and the rear midranges should be replaced as well. That made for the best end result. I think I might go at this in two steps - Alpine kit and recode first, then subs and midranges later. However, would be nice to be able to keep an eye out for the right parts. Re subs: I haven't been able to find L7 subs (used, brand new is a bit too pricey for my wallet) within Europe (mainly been looking on eBay) so are there any suitable alternatives that would work well with the Alpine set? Re midranges: Would the best bet be a set of the same Alpine midranges that goes into the front doors? Or is there a better alternative? Cheers, H. |
07-22-2015, 09:34 PM | #10 |
136
Rep 1,192
Drives: 2011 335i MT
I would go to a local sound shop that does BMW upgrades, listen to some options (Focal, Jehnert, etc.) and then decide. Use the forum to find options and use your ears to decide what to buy! Check out the Jehnert loaded doorboards. Very inexpensive considering what you get.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
07-22-2015, 11:11 PM | #11 |
382
Rep 2,366
If you want to stick to OEM speaker locations without losing your door storage, the jenhert 3-way kit (flatline?) is a drop in replacement that gives you underseat woofers, front mids, and front tweeters.
Remember, if you code to hifi, you'll need an amp too (which you will not have if you're starting with base audio). |
07-23-2015, 05:18 AM | #12 | ||
Rep 44
I am aware that recode to hifi means amp - the front tweeters, midranges and under seats will be driven off the amp, while the two rear midranges will be running off of the HU (now flat EQ because of the recode). It is in that scenario that I am wondering which replacement for the rear midranges to get? ------- Just to sum up, what I was envisioning was this: Phase 1: A. Alpine retrofit kit, meaning: - Tweeter installation in front doors - Midrange replacement in front doors - Amp installation in boot - Harness installation B. Recode HU to Hifi Phase 2: C. Drop-in replacement of - Under seat subs (but what to get that would work well with the Alpine amp and overall sound now that L7s are hard to find?) - Rear midranges (but what to get that would be balanced well (sound wise) with the rest of the setup, since these would be running off the HU which is now recoded and has another output power?) Cheers, H. |
07-23-2015, 08:32 AM | #13 |
382
Rep 2,366
If you recode to hifi, you won't be able to drive any speakers directly from the HU. Even the rear speakers will need to be amped.
07-23-2015, 10:24 AM | #14 | |
Rep 44
What confuses me is that in the install thread by makkan00 I referenced earlier (found the link: http://www.e90post.com/forums/showth...ghlight=alpine), he is adamant about recoding to hifi and yet there is no mention of output power to rear midranges being an issue - and there isn't indication that the rear midranges are powered by the amp. Which would also require midification to the provided harness, I would think? What am I missing? Cheers, H. |
07-23-2015, 10:33 AM | #15 | |
382
Rep 2,366
Check the stickies in this forum, I'm sure the info is clearly listed there. I still strongly believe that recoding to Hifi requires all speakers to be amped. Doesn't the OEM amp in a car with Hifi audio power the rear speakers too? I think it does. Only difference between the front and rear HU outputs I can remember is that the rear outputs are high pass filtered, so you can't tap into them for a sub signal. Good luck and let me know if I'm wrong! (or right )
07-30-2015, 07:03 AM | #16 | |||
Rep 44
I have made up my mind and ordered the Alpine kit (-268, the non-splice version) and have a couple of L7 underseats on their way to me from the US (had a very hard time finding these in Europe, at least at a reasonable price - including shipping and tax they'll run me up $260). Got the sails and foam inserts the other day, so that's taken care of. So while I wait, I will work on getting the coding environment up and running :-) Cheers, H. |
07-30-2015, 10:55 AM | #17 |
1917
Rep 13,114
Some of us regard the rear speakers as useless.
The stereo purists here. Indeed one of the most respected install shops use to say "Rear Speakers are a Communist Plot" Also I thought there were two versions of the Alpine kit one that required coding and one that didn't. Last edited by ctuna; 07-30-2015 at 11:57 AM.. |
07-30-2015, 11:25 AM | #18 |
382
Rep 2,366
I'm guessing the many of you who disregard the rear speakers (and even disconnect them in many cases) either have coupes or are otherwise unconcerned about potential back seat passengers
I often carry passengers in the backseat of my sedan, and like to provide them with a nice balanced audio experience while seated there. For me rears are needed for this, otherwise the bass is too overpowering with no mids/highs close to their ears to balance the sound. I still need to upgrade my rears, but even the base audio stocks are better than nothing (maybe barely) |
08-02-2015, 02:59 AM | #19 |
台灣人
36
Rep 386
I am done with the Alpine upgrade and so far the outcome is satisfied.
The rear speakers are powered by the HU and much weaker than front speakers after coding the car with $676. I won't touch the rear until I get another set of upgrade speakers and another amp to drive them. The difference between by just adding tweeters to the front with base audio and Alpine upgrade, Alpine upgrade is the way to go. It sounds much wider and no mixing up on high and mid freqs. The base sub are bit weaker to be handled by Alpine amp, so getting L7 subs or SWS-8 may be an option. Last edited by ckegg; 08-02-2015 at 03:11 AM.. |
08-02-2015, 05:48 AM | #20 |
Rep 44
Hey ckegg,
thanks for sharing! Intimidating to see the car field stripped like that :-) As you are in the US, there are more options for used L7s available to you (most L7s on eBay are in the US) . It seems that in the Alpine setup, people go for the L7s. Out of interest, were there any issues regarding cable length and left/right hand drive installation and were the tweeter crossover cables still mislabeled? Did you pay special attention to cabling so as to avoid running speaker connections along power cables? Cheers, H. |
08-02-2015, 11:13 AM | #21 |
台灣人
36
Rep 386
Heylel
The cable is not long enough for you to really go alone with other factory looms. If you look at the last picture I posted, the red single power cord is the Alpine power cord and I could not tie it with the factory loom together because it is bit shorter. For cables going to subs, they are just long enough if you go on lower edge of the rear seat. Again, if you look at the factory loom, they go above the rear suspension top cap, but Alpine cable is not long enough to reach it. Therefore, to be safe I connect cables to subs before tie anything up. Just look at the Alpine installation manual then you know what I am talking about. |
