07-15-2015, 02:36 PM | #1 |
432
Rep 887
Drives: Enzo F23 228i
Exhaust Flapper Tech Bulletin
So, my exhaust flapper started to rattle the other day, and I crawled under to take a look and when I pulled on the spring clip, "pop" it came right out!
Called the dealership and explained the situation and sure enough, tech bulletin came out for "rattle noise" in exhaust. They did the repair and all is well again...something about the heat shield and bolts. |
07-15-2015, 03:25 PM | #2 | |
204
Rep 757
07-15-2015, 04:42 PM | #3 |
432
Rep 887
My service manager didn't mention if it was just oem mufflers or if it went across all mufflers, it was about the servo, and your mpe has a servo. I'd check!
07-15-2015, 07:22 PM | #5 |
432
Rep 887
That's great! Mine wasn't plugged in and I had the rattle...it's a servo thing so it's not effected by power.
I also noticed that putting your car in sport + and unplugging the harness doesn't change the valve position...hence why most are saying it makes little to no difference. |
07-15-2015, 08:15 PM | #6 |
1836
Rep 4,203
I unplugged it when it was cold and I guess it has been unplugged almost from the beginning it is tight enough not to rattle. Now sometimes I think I hear something but not enough to worry about and i also have the mPE
07-15-2015, 08:31 PM | #7 | |
1399
Rep 5,262
07-15-2015, 09:01 PM | #8 |
432
Rep 887
Well...I'd have to jack the car up again cause I'm too fat to crawl underneath!
I can say that the clip is a u-shaped rod about the thickness of a coat hanger and it is compressed when the solenoid is attached to the exhaust bracket. Both the solenoid and the actual flapper valve have a straight groove that the spring sits in, and the compression is what holds it in place. It fills the 1/2" gap between the flapper and the solenoid. Helpful? |
07-15-2015, 09:06 PM | #9 | |
1399
Rep 5,262
07-15-2015, 09:10 PM | #10 |
432
Rep 887
I did take a pic when it was out of the car:
08-17-2015, 02:38 PM | #12 |
432
Rep 887
The heat shield...which is the metal cover that protects the servo.
