07-09-2015, 09:39 PM | #1 |
42
Rep 503
Charge Pipe failure...again
So I was merging onto the freeway today and my 2014 335i suddenly lost power and stopped accelerating. Fun times. I was able to get off the next exit and when I popped my hood I saw the chargepipe (I think it's the chargepipe) had popped off.
This car is only 18 months old, and while I am a slightly spirited driver, I have never tracked the car and very rarely use full acceleration. This is the second time this has happened, the first was just a couple months after I got the car. She is at the dealer now getting repaired, but this is pretty annoying and really gives me little confidence in BMW's quality (this is my 5th BMW) these days. Would you guys recommend I get an aftermarket charge pipe that would likely be more reliable? If so, how would that affect the warranty? And how easy is it to install myself? Thanks for the advice. Pics included. |
07-09-2015, 10:13 PM | #2 |
Dream crusher
984
Rep 2,421
All stock or any mods?
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
07-09-2015, 10:27 PM | #3 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
I never had mine blow off like that, odd. I wouldn't surprised if they didn't put the retaining clip on correctly when they installed it for your first repair. But one of my first mods was replacing the charge pipe, and I haven't had an issue with it yet and I've gone up to 25psi. It is a pain in the ass to install though, doesn't require any special tools.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
BM235iW97.00 |
07-09-2015, 10:53 PM | #4 |
BimmerPost Supporting Vendor
24199
Rep 190,807
Time to get the Evolution Racewerks Charge pipe
07-10-2015, 06:18 AM | #6 |
Pace Car Driver
1548
Rep 3,164
Can't tell from the pic, is it broken or did it just come off?
That does suck that an OEM part like that would fail under normal conditions but..... So, if it did break, is there the chance that small broken pieces get ingested by the intake? |
07-10-2015, 08:11 AM | #8 | |
4918
Rep 115,980
The only permanent solution is to get an aftermarket (ER) charge pipe. We've sold 1000+ of these for the N54/N55 without any warranty issues. Mike |
07-10-2015, 10:05 AM | #9 |
649
Rep 4,323
Just get the ER one...
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
07-10-2015, 01:11 PM | #10 | ||
37
Rep 243
JB4 Stage 2 | aFe Magnum FORCE Intake System DRY | ER Chargepipe | ER CATLESS Downpipe | ATM Intercooler | BMS 2.3 Gal Meth Inj kit | Bilstein B14 | OEM Slotted/Dimpeled front rotors | Cool Carbon brakes | Go Fast Bit DV+ | Pure Stage 2 Turbo | Pure inlet
07-10-2015, 01:38 PM | #11 | |
42
Rep 503
You are correct, in this picture it looks like it just popped off. Last time I had this happen, about 9 months ago, the pipe actually cracked and broke off. Waiting to hear from the dealer what the issue was. |
07-10-2015, 01:54 PM | #12 |
55
Rep 467
07-11-2015, 08:41 PM | #13 | |
4918
Rep 115,980
Mike |
07-14-2015, 09:44 AM | #14 |
3441
Rep 79,211
Is it just popping off?
If so then it's likely not installed correctly. If that C clip isn't perfectly seated this will cause that issue. When it's installed it needs to be firmly in place and the C clip needs to click. If a BMW mechanic is doing the work then you'd hope they would know this. If it's installed correctly and keeps popping off then I'd suggest an upgrade. Although BMW should fix the issue, I personally try to avoid dealers at all costs. Every time I bring my car to a dealer it's scratched, dented or the interior is messed up (seriously). I'd just get the ER and this is not the salesmen in me telling you. |
07-15-2015, 02:55 AM | #15 | |
42
Rep 503
My dealer here is pretty good. That is nice because it is the only BMW dealer on the island. So my options are pretty limited. Never had any major issues with them. I'll definitely be considering upgrading the chargepipe in the near future (just bought a house and renovating the entire place so short on cash now). My only concern there is voiding my warranty for any reason since I got the extended warranty and plan to keep this car for a while. We will see what happens. I'm looking on the bright side, my car must be far more powerful than your standard 335i if it keeps cracking the chargepipe. |
07-15-2015, 08:17 AM | #16 | |
4918
Rep 115,980
Mike |
07-15-2015, 11:42 AM | #17 | |
3441
Rep 79,211
If you have to go to dealer for anything you can swap it back in a half an hour or less if you are proficient. Most dealers won't care about the CP though. Especially knowing/understanding your oem already broke twice, IMO. |
09-30-2015, 07:42 PM | #19 |
94
Rep 389
Drives: '13 F30 335i MSport
Cracked my CP today. JB4 on map 1 and intake. In sport mode dipped in about 60% tryna to maintain traction, hit 3rd and POW!WTH come on BMW.
2013 GSM 335i MSport
09-30-2015, 08:31 PM | #20 |
Out Boosting...
242
Rep 3,987
haven't blown my stock one and I'm running map7 with 106octane gas and intake jb4 and downpipe lol!!
Alpine White M-Sport F30
09-30-2015, 09:07 PM | #21 |
793
Rep 1,627
how many miles with this set-up?
M4 in MG | 6 MT
10-01-2015, 07:14 AM | #22 |
153
Rep 397
