2010 2011 BMW 5 Series Forum F10 Dual to Quad Tip Conversion |
07-08-2015, 11:07 PM | #1 |
185
Rep 947
So ... I'm looking to swap out the OEM diffuser on my 535D MSport with the 3D Design carbon fibre diffuser and thought I would look for recommendations from peeps as to their conversion from dual to quad tips. I'm assuming the 3D Diffuser will allow the dual tips to poke through (looking a little naff in the interim) while I wait to do the exhaust/tip conversion
Can you tell me your respective experiences on best conversion - do I need to swap out the rear muffler as well or can I simply get tips to attach, the latter being my preference? The tips that appeal to me are the double insulated trumpet tips like IE92 had on his original Azzure Blue modded 528 but I can't seem to source them anywhere . Any ideas and or recommendations greatly appreciated .
Current Mistress: 2014 F10 535D M Sport - Alpine White
Retired but not forgotten: 2011 F10 535i - Titan Silver; E53 X5 4.4L Sport - Space Grey; E46 M3 Individual Convertible - Phoenix Yellow; E39 528 - Glacier Green; E36 328 Convertible - Montreal Blue |
07-09-2015, 05:15 AM | #2 |
9159
Rep 14,521
We did have a thread going on about some 3.5" and 4" tips a fellow member found. Carbon fiber tips same one's used on the akrapovic exhaust but they were money . Ill have to find that thread.
07-09-2015, 08:44 AM | #5 |
9159
Rep 14,521
07-09-2015, 09:25 AM | #6 |
94
Rep 413
Hi Jet! When doing dual to quad conversion, you have a number of options, let me list it from the cheapest to the expensive:
- stock mufflers, 550i diffuser, aftermarket quad tips (Cyba Quad, Megan Racing Quad, etc.); - replace mufflers (Magnaflow, 550, M5 etc.) with the tips at your choice, 550i diffuser; - replace mufflers, aftermarket diffuser (e.g. M Performance, carbon 3D Design, Vorsteiner etc.); - replace axleback (550, M550D, Eisenman Street or Race, Supersprint, etc.) and aftermarket diffuser; - replace catback (maybe get x-pipe instead of the mid-resonator), aftermarket diffuser. Here is my own project I have done last year: http://f10.5post.com/forums/showthread.php?t=1049887 Full SS catback ($2.5k) Vorsteiner M5 carbon ($3k) and conversion work ($1k). As you can see, all depends on preferrable aestetics and your desirable budget. You may decide to get things from ebay or also buy the used ones - this is a good money saver. The last note. If you will want to use the M5 pieces (diffuser or catback), remember: the tips of M5 are narrower than of any 5-series (see the pic below), so be aware the fitment will need extra work. |
07-09-2015, 10:55 AM | #7 |
9159
Rep 14,521
Nice! Valbmw u always come in with a lot more info on any topic! hence all the info u gave me regarding diffusers. Is it me or does the 550 have a smaller pipe diameter?
07-09-2015, 12:22 PM | #8 |
94
Rep 413
Thank you Well, you're right, it does: referring to the realoem.com, the 550 pipes have clamping bushes on them of D=70MM when the M5 pipes have them of D=80MM.
The idea is simple: when retrofitting the car with an upgrade such as full catback from the senior model or even the aftermarket one, it comes with larger pipes and lesser resistance, also it is normally lighter. So you save 10-15 kg of weight and gain 5-10 bhp (plus aestetics) at the cost of $3-4k (not to forget another bill for some carbon chunks). If changing exhaust tips only, this is only for better look, but some find it sufficient. |
07-10-2015, 02:20 PM | #9 | |
185
Rep 947
07-10-2015, 03:04 PM | #10 | ||
185
Rep 947
07-10-2015, 03:42 PM | #11 | |
94
Rep 413
https://a-a.d-cd.net/2ce01d4s-960.jpg https://d-a.d-cd.net/b0e01d4s-960.jpg http://i62.photobucket.com/albums/h9...psedc46211.jpg http://i62.photobucket.com/albums/h9...ps0f130fa6.jpg http://i62.photobucket.com/albums/h9...ps1cb15397.jpg |
07-10-2015, 07:02 PM | #12 |
9159
Rep 14,521
Those look sweet! someone here posted for sale their quad exhaust for a 528 and it looked just like the pictures Valbmw posted. |
07-11-2015, 06:21 AM | #13 | |
185
Rep 947
07-11-2015, 07:17 AM | #14 |
94
Rep 413
Diffuser on the white car is OEM M5 painted gloss black.
Tips are Dimisa, custom fitment to M5. Diffusers on the black car is 3D Design M5 carbon, just have a look: http://f10.m5post.com/forums/showthread.php?t=846544 http://ind-distribution.com/ind/bran...-rear-diffuser http://www.precision-sport.com/shop-...-rear-diffuser http://www.flickriver.com/photos/eur...ce/8372034754/ http://www.trinityautosport.com/desi...ser-p-616.html Tips are Dimisa, too, with custom fitment to M5. And the last one... wait! you are showing me my own car's ass This is Vorsteiner M5 (and the car is actually carbon black) http://f10.5post.com/forums/showthread.php?t=1049887 You can see, all these sexy diffusers with big and cambered side wings and the large and single middle part are for M5. The diffusers for 5-series are more flat and need to be linked to a plastic shield which is attached to the "spare weel" niche with 3 bolts. M5 diffuser are bolt-on without any screens. The M5 diffuser is much better looking but also has one problem: the tips should sit closer to the centre, like 2" each side: Therefore the shape of the tips piping might be not "Y" but "Ч" (your exhaust shop tech will check it out and decide): This custom fitment is totally doable and is not very difficult for a proper tech, believe me. My own fitment story was different because I've got the full Supersprint catback so adjustment exercise was more difficult. Last edited by valbmw; 07-11-2015 at 07:32 AM.. |
07-11-2015, 08:33 AM | #15 |
1569
Rep 29,202
Any pics of your car, Jet?
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
07-11-2015, 08:17 PM | #16 |
185
Rep 947
Sorry Remmib. No pics until I get the mods I want completed - diffuser, exhaust, and shoes to go yet. I need to save my pennies for the rims I want as they are hovering around AUD$12,000
07-12-2015, 05:59 AM | #17 |
1569
Rep 29,202
I guess you wants some HRE wheels, too bad about the expensive USD for us foreign guys now.
07-13-2015, 01:43 AM | #19 | |
94
Rep 413
BTW Audi made "Audi Active Sound" as a great example of smart business responding to the specific market demand ("Making tailpipe music", "No more silent running"): http://articles.sae.org/6737/ http://schawe-cardesign.de/audi-a5-8...d-sound-modul/ http://www.audiblog.nl/2011/09/audi-...uitlaat-video/ http://maxhaust.de/komplett-set-acti...udi-a7-4g.html http://www.ebay.de/itm/Nachruestsatz...-/371189288930 |
07-13-2015, 01:46 AM | #20 | |
94
Rep 413
BTW Audi sells the "Audi Active Sound" as a great example of smart business response to a specific market demand ("Making tailpipe music", "No more silent running"): http://articles.sae.org/6737/ http://schawe-cardesign.de/audi-a5-8...d-sound-modul/ http://www.audiblog.nl/2011/09/audi-...uitlaat-video/ http://maxhaust.de/komplett-set-acti...udi-a7-4g.html http://www.ebay.de/itm/Nachruestsatz...-/371189288930 |
07-13-2015, 07:39 AM | #21 | |
185
Rep 947
- install any MSport style diffuser (such as 3D Design MSport, Vorsteiner M Sport Aero, etc) and install 'Y' style tips; or - install an M5 style diffuser (such as OEM M5, Vorsteiner M5, etc) and instal 'Ч' style tips. Let me know if I have that wrong. BTW, the ass on your ride is sensational. Gives me goosies lookin at it.
07-13-2015, 08:20 AM | #22 | |
94
Rep 413
The black 528i conversion in details (3D Design + Arqray 90mm M5 axleback + Dimisa http://www.dimisatips.com/): https://h-a.d-cd.net/7455414s-960.jpg https://h-a.d-cd.net/7f35414s-960.jpg https://e-a.d-cd.net/84f1414s-480.jpg https://h-a.d-cd.net/b0cd414s-960.jpg https://a-a.d-cd.net/74cd414s-960.jpg https://f-a.d-cd.net/76cd414s-480.jpg https://b-a.d-cd.net/9c87a74s-480.jpg https://c-a.d-cd.net/c287a74s-480.jpg https://c-a.d-cd.net/c287a74s-480.jpg https://f-a.d-cd.net/b287a74s-480.jpg https://h-a.d-cd.net/5a87a74s-480.jpg https://d-a.d-cd.net/8687a74s-480.jpg https://a-a.d-cd.net/9687a74s-480.jpg https://b-a.d-cd.net/8180674s-960.jpg The white 535d has (if I remember it right) a custom catback exhaust with M5 mufflers and Dimisa tips, OEM M5 diffuser painted: https://e-a.d-cd.net/fc6e9d4s-960.jpg My car has factory catback Supersprint, Vorsteiner Aero M5 diff and the tech did perfect job bending the pipes so that 5-series catback got adjusted to M5 diffuser. Finally, you are right with the two options. This is the most simple way, without need to have the pipes bended or the mufflers modified for the "||" tips. Last edited by valbmw; 07-13-2015 at 08:42 AM.. |
