07-08-2015, 03:33 PM | #1 |
Supreme Leader
2283
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
SUPREME POWER l Bilstein PSS10 (M235 & 228i)
Bilstein's best and hottest suspension setup is now available for the F22 2 series coupe. This system features 10-way adjustable dampeners/shocks and front and rear ride height adjustment. This is one of our favorite "trackable" street suspension setups, great for any 2 series (228i and M235i) BMW. On the softest settings, it's compliant enough for typical city and highway driving, and on the firmer settings it's firm and sure-footed enough for occasional track driving. Whether you plan to track your car or not, you'll love the handling transformation of the PSS10. To insure maximum performance, these systems utilize Bilstein's superior monotube gas shocks, featuring: Largest available piston diameter for greater sensitivity and precise control. Patented digressive piston head design and deflective valving instantly reacts to changing road conditions. 10-way adjustable dampening knobs that "click" from soft to hard with no tools or jacking required. Monotube design dissipates heat more effectively than a twin tube shock for cooler, more efficient operation and longer life. Weather resistant coating to resist oxidization, and ensure long life. Lighter weight reduces wear and tear on suspension components. Ride height is adjustable from -1.0" to -1.75" front & -1.0" to -1.75" rear (minimum 1" lowering) Wrenches to adjust front and rear ride height included! 10-way hand-adjustable shocksThe Bilstein PSS10 Suspension provides the ultimate in performance tuning. The fully-adjustable monotube gas shock absorbers offer a selection of TEN precise compression and rebound settings, from comfort to competition. Each setting "clicks" into place, and a labeled indicator lets you know exactly what setting you are on, without any counting of clicks. The front and rear progressive rate springs allow accurate adjustment of the vehicle ride height and center of gravity for the level of performance you seek. Now you can enjoy the kind of precise suspension tuning formerly available only on race cars. The PSS10 system puts you in complete control. Whether it's a weekend of competition or the daily commute, absolute handling and control are just a few twists away. On the softest setting, this suspension is amazing compliant for street driving, while the firmest settings tighten your BMW into a track carving road-course handler. This coilover kit fits the following BMWs:
*EDC Delete module required for cars with EDC
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. Last edited by supremepower; 07-08-2015 at 05:07 PM.. |
07-08-2015, 06:39 PM | #2 |
560
Rep 1,503
What does the EDC delete module look like?
Also, I was told that one EDC is deleted it cannot be reversed. Or could be but requires a lot of splicing and work. |
07-08-2015, 06:56 PM | #3 |
Supreme Leader
2283
Rep 6,548
That may be the case if you code it out, but the edc delete module is box that holds the programming to remove the suspension light. Simple plug-in unit
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. |
07-08-2015, 06:58 PM | #4 |
560
Rep 1,503
So if I simply use the edc delete module any suspension light will clear? And when I go back to stock suspension, I can just unplug the module and have EDC again?
07-08-2015, 09:48 PM | #6 | |
Supreme Leader
2283
Rep 6,548
SupremePOWER
07-08-2015, 09:49 PM | #7 | |
Supreme Leader
2283
Rep 6,548
SupremePOWER
07-10-2015, 06:13 PM | #8 |
127
Rep 765
Please send me a PM (to zip 98327) for the PSS10 kit with EDC delete modules. Also, your explanation of the EDC delete modules clears up a lot of questions I had as well. Thanks much!
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
07-10-2015, 06:16 PM | #9 |
Supreme Leader
2283
Rep 6,548
No problem. I'll PM you right now
SupremePOWER
07-14-2015, 06:37 PM | #10 |
127
Rep 765
Do you guys sell KW coils as well? I am reading that the KW V1s are softer on daily drives while the B14s tend to be more track oriented. Is that the typical observation between the two sets?
07-14-2015, 07:53 PM | #11 | |
Supreme Leader
2283
Rep 6,548
PM coming your way
SupremePOWER
07-15-2015, 10:17 PM | #13 |
Supreme Leader
2283
Rep 6,548
Yessir, Bilstein B14 Part #: 47-207233
SupremePOWER
07-16-2015, 11:28 AM | #15 |
Supreme Leader
2283
Rep 6,548
EDC Module will be needed if you have adaptive suspension
SupremePOWER
08-01-2015, 10:35 AM | #17 |
BD_e92
358
Rep 1,748
08-02-2015, 02:53 PM | #18 | |
Supreme Leader
2283
Rep 6,548
http://www.kwsuspensions.com/product...ete-units.html
SupremePOWER
08-29-2015, 05:00 AM | #20 |
14
Rep 73
08-30-2015, 08:25 PM | #21 | |
Supreme Leader
2283
Rep 6,548
PM with price coming your way
SupremePOWER
