07-07-2015, 09:01 PM | #1 |
354
Rep 464
335 speed limiter
hey everyone,
I have searched this and a few other forums on speed limiter info, with some limited return on direction, i drive a f30 335 xdrive, i really needed all season tires however i also made the mistake of not knowing about option 840, there are a few tracks around me with long back straights and im looking for options. I have seen there are no more SLD from burger tuning for the f30, and the mppk does not solve the issue, is there anything else besides a proper ecu flash ? Thanks |
07-08-2015, 03:49 AM | #4 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
mine is limited at 167 mph from the factory, i guess that means i have option 840?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
07-08-2015, 03:58 AM | #5 | |
677
Rep 1,349
Drives: BMW F80 M3
Mine was tested on the road with pbox. At 260 kph on the tacho the car stops accelerating due to the limiter. This was 248 gps kph. Now the limiter is removed via flash. So far i have done real 267 gps measured kph. Without flash not possible at this time to remove the limiter. |
07-08-2015, 04:05 AM | #6 |
515
Rep 1,063
Its what my heads up display said. Did it on a 20 mile stretch of empty highway. My buddy had his S63 with a limit of 187mph so he confirmed it with his tach too. This was done before any of my big mods, just a jb4, downpipe, exhaust and intake.
07-08-2015, 06:34 AM | #7 | |
Rep 45
07-08-2015, 12:32 PM | #8 |
451
Rep 469
How long are the long backs? My 335i mppk (240kW version) needs a mile to accelerate from 0-155mph. Besides that you need some distance to brake before you turn. Even though you would be able to go beyond your top speed that isn't what makes you go fast around the track. The time is won by fast cornering.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
07-08-2015, 01:15 PM | #9 |
354
Rep 464
Its a 3.6 mile track with a good straight, i understand what you are saying, however i feel that its not just hitting a wall at 130 but more so the characteristic of acceleration towards there is different, i dont know if im imagining things
07-08-2015, 01:24 PM | #10 |
451
Rep 469
The tracks we have in Denmark are quite short and the maximum speed I have reached is about a 110mph on a about quarter mile straight. I posted a video in this thread from the track: http://f30.bimmerpost.com/forums/sho....php?t=1116614
However I often drive in Germany with no limits and I can tell you that when I cruise at 130mph there is still plenty power and you can still feel the acceleration all the way up till 155mph. But before doing any mods I would take a test on the track and see if you hit the limiter. If not there is no need to have it removed.
07-08-2015, 02:32 PM | #11 |
Rep 9
I would be interested as well in a product like this:
Burger Motorsports N54 BMW Speed Delimiter (SLD) - http://www.burgertuning.com/BMW_Speed_delimiter.html Terry? Or Anyone? |
07-08-2015, 02:35 PM | #12 |
451
Rep 469
There is this one for N55s from G-power: http://www.g-power.com/artikelbeschr..._1636.php#1636
07-08-2015, 03:03 PM | #13 |
127
Rep 851
I've capped out at 130-135 mph and I have the EXACT same car as OP. Confirmed.... dont ask where lol. Kinda ticked because the car can easily get to like 175 probably modded.
07-08-2015, 04:54 PM | #15 | |
515
Rep 1,063
07-08-2015, 09:55 PM | #16 |
649
Rep 4,323
a flash tune can eliminate it.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
07-08-2015, 11:08 PM | #17 |
560
Rep 1,503
07-09-2015, 10:52 AM | #18 |
451
Rep 469
A flash tune isn't that easy. For the F3x you have to physically open the ECU and do mods to it, with all the risks that it implies, before you can flash it.
After that you flash it as you would like to.
07-09-2015, 10:53 AM | #19 |
451
Rep 469
That is just the new limit. Gives you room for performance improvements
07-09-2015, 10:59 AM | #20 |
BimmerPost Supporting Vendor
24203
Rep 190,807
07-09-2015, 11:05 AM | #21 |
Rep 45
My reasoning is running intake/FMIC/DP/exhaust with jp4 on meth would, I imagine get you over 400bhp at the crank, on a long straight that means over 130mph easy, I don't want to hit fuel cut on a back straight, that actually throws off your race line
07-09-2015, 11:06 AM | #22 |
24203
Rep 190,807
Where in the US are you able to hit 130 mph ?
