Brembo Brake Pads for 335i
07-06-2015, 08:24 AM | #1 |
Impys
Rep 49
I am thinking got buying the brake pad below for my 335i 09 from Amazon
Are these better than the OEM ones? Does anyone know of any issues with these? Brembo P 06 045 Front Disc Brake Pad, Set of 4 £68.89 Brembo P06039 Rear Disc Brake Pad, Set of 4 £33.50 MAPCO Warning Contact, brake pad wear (56617) £8.16 Any advice would be appreciated |
07-07-2015, 08:19 AM | #5 |
146
Rep 2,337
Bosch are not a bad alternative to OEM
http://www.amazon.co.uk/dp/B00BHI654...=IZZA018RDEVGQ If you don't want extra performance, I'd not bother spending too much money. Avoid really cheap pads though, you'll just end up swapping them again before you know it. |
07-08-2015, 06:59 AM | #6 |
24
Rep 189
I went with Textar pads and there good for the money. Was advised by a few forum members that there the best OEM quality pads. Obviously no good if your tracking your car or used to harsh braking.
Ben |
07-09-2015, 01:48 PM | #7 |
28
Rep 308
I have both pads and discs...can't say they are any better than OEM...maybe a little less fade..but the do squeak is annoying
Jb4 with Trebila BEF,vargas stage 2+ turbos, vrsf dp's, vrsf cp with tial bov, vrfs 7" fmic, EOS PI with BMS PI controller, RB Inlets and Outlets, bms meth kit, BMS DCI, miltek cat back, bms occ,3.5 tmap, ngk 5992 plugs, HSD coilovers, M3 rear subframe, diff, drive shafts , suspension and brakes.
