Reversed Brake Force Display possible?
07-04-2015, 06:25 PM | #1 |
68
Rep 715
Is it possible to reverse the brake force display through coding? For example, from stock, only the outer lights illuminate when braking. Under hard braking, the inner brake lights illuminate as well. I know it's possible to code to have BFD on at all times (outer + inner light illuminate at all braking levels) but is it possible to swap the function of the inner and outer light? E.g. under normal breaking, only the inner light illuminates and have the outer light serve as the BFD under hard braking?
07-07-2015, 09:27 AM | #2 |
60
Rep 675
I'm thinking it's possible. You have to turn on the inner lights at normal braking and set the voltage on the outer to 0. For bfd you have to set wich the only outer. Not sure if it's only possibe with frm2 and ftm3.
