07-04-2015, 07:40 AM | #1 |
75
Rep 78
JB4 Drivetrain Malfunction?
Hey guys,
I just recently installed a JB4 tuner on my 435i. It seems to work well, but whenever I flood it, I get a drivetrain malfunction error code. I don't get any loss of power and the overall performance isn't affected. Is this something I should worry about? I don't like seeing error codes and I want to make sure this isn't something potentially bad. |
07-05-2015, 06:57 AM | #8 |
Pace Car Driver
1548
Rep 3,164
07-05-2015, 09:39 PM | #9 | |
BimmerPost Supporting Vendor
12971
Rep 18,716
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
07-06-2015, 11:32 AM | #10 |
24198
Rep 190,807
I would start by checking installation , then update the firmware.
Try to drive the car again and see if you are still having problems. If you are , use the USB cable to pull the codes.
07-07-2015, 10:14 AM | #13 |
Pace Car Driver
1548
Rep 3,164
07-07-2015, 04:58 PM | #15 |
4918
Rep 115,980
10-20-2015, 05:39 PM | #18 |
60
Rep 541
Any update on this OP? I have same issue. Proper firmware and all.
Now: 2012 F30 335i / 6MT / JB4 / ER Catless DP
Sold: 2010 Jeep GC SRT8 Sold: 2007 E90 335i / 6MT / JB4 / Vishnu Exhaust / VMR 710 19" / BMS DCI / HKS Blow Off Valve / Tinted Tails / Clutch Stop |
10-20-2015, 06:57 PM | #19 |
4918
Rep 115,980
08-03-2016, 09:48 AM | #20 |
17
Rep 122
bump...going through the same motion after installation. Installed the latest PWG firmware from the N55 jb4 thread.
JB4 works but the car will throw the code sometimes without actual loss in output. Everything is connected except the flex fuel connector, actually didn't plug the female/male harnesses together on the JB4 (that's how i interpreted the installation lol) When I check for codes via laptop, says there are none...and when I restart the car it goes away to only come back later. |
08-03-2016, 09:55 AM | #21 |
243
Rep 447
I have had this error with a different piggyback when I disconnect the battery and either install or return to stock. Upon initial start up I get that indication, it then goes away and never returns, no codes thrown.
Not sure if you guys are getting this indicator more than the 1 time post initial install, or if it's like my situation. I think it is normal following battery disconnect and initial startup, at least that has been what I've seen.
'15 M235xi | BSM/Oyster/Aluminum | Black Kidneys | RW Carbon Mirror Caps | 40% tint
08-03-2016, 10:07 AM | #22 | |
17
Rep 122
I get it often enough every time I drive, it will go away sometimes.
Just wondering what is causing the issue. I've read horror stories from guys cars just stopping mid drive (steering locks up, loss of power). Quote:
