Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Forge Motorsport Diverter Valve (N54)
      02-16-2008, 10:43 PM   #1
doba_s
doba_s's Avatar
405
Drives: X7 l Cayenne l 997.2RS
Arrow DIY: Forge Motorsport Diverter Valve (N54)
I just want to share with you guys some helpful information on how to install Forge Motorsport Diverter Valve (N54). It comes with the installation instruction and you will be fine just by doing what they tell you to do. I just want to add my 5c to it.
1. After you installed your new valves , I would recommend you to cut a little bit those hoses.
Diverter Valves installed
2. I would also recommend to lubricate both ends of the hoses. You can use one drop of motor oil to do that. I shortened the hoses by about 1 inch or so. I just was going little by little until the fitment was perfect. By doing that you will have a small gap in between your new vales.
3. Now you can put everything back.
It would be much easier to put it back by lubricating those parts on the air box
I hope it will help you a little bit. If you have any questions feel free to ask me.
      02-17-2008, 12:00 AM   #2
XPO186
XPO186's Avatar
Philippines
128
Drives: E92 335i
Awesome job Aleks !!!
Come over when I install mine...
      02-17-2008, 12:39 AM   #3
doba_s
doba_s's Avatar
405
sure man ... i'm always glad to help
      02-17-2008, 09:48 AM   #4
dreamk
Dominican Republic
122
Drives: 335i
2007 e90 335i  [0.00]
what does it do??
      02-17-2008, 10:44 AM   #5
doba_s
doba_s's Avatar
405
Originally Posted by dreamk View Post
what does it do??
      02-23-2008, 02:35 AM   #6
Tuned335i
24
Drives: E92 335i
Did you use anything special to shorten the hoses? I haven't installed mine yet but plan to in about a week and your install looks pretty clean.
Great clear photos by the way!
      02-23-2008, 12:28 PM   #7
doba_s
doba_s's Avatar
405
just use very sharp knife and something to cut the steel wire ...
      02-23-2008, 12:53 PM   #8
cn555ic
cn555ic's Avatar
441
Drives: 335i
I am adding my 2c too...When you twist the DV locking mechanism, you should wear a pair of gloves to help you get some grip.
      03-08-2008, 11:34 PM   #9
Tuned335i
24
Drives: E92 335i
It's probably been posted before, but the Forge instructions regarding which way to turn the grey clips are correct for the hose ends attached to the factory DVs (clockwise), but the at the stock hose ends, you turn them counterclockwise, the opposite direction from the grey clips at the DVs. I just installed mine tonight and got hung up on this step momentarily.
Also, as most others have done, I cut exactly 2" from the shorter front hose and I also cut 1/2" from the rear hose. You need a good pair of wire cutters to cut the steel wire that wraps inside the hose.
I have a boost gauge and I had extra length in my hoses so I clocked the vacuum nipples towards the driver-side which was less complicated than clocking them towards the passenger side as per the Forge instructions. Here's a photo:
A couple other places that were more difficult than I expected:
1.) If you're using the factory vacuum hoses, they are really difficult to get on the vacuum nipples on the Forge DVs. They look like they were sized for a larger than stock vacuum hose.
2.) Removing the three grey rubber grommets from the airbox is very easy if you take a flatblade screwdriver and insert it into the rubber grommet on the far side between the grommet and the airbox plastic fin. Slide the screwdriver to the front and rear edges of the grommet slot to release the rubber from the plastic piece while you pull up. This makes it a piece of cake.
      03-09-2008, 10:00 PM   #10
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
how long would it take to put the stock valves back in? I don't want any reason for the dealer to deny a claim should something come up
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
      03-20-2008, 12:18 AM   #11
Tuned335i
24
Drives: E92 335i
Once you've done the install, I imagine it would take about 1/3 less time to go back to stock for service. The only thing that took time for me was figuring out that the direction to turn the grey ring on the OEM DVs was wrong, and cutting the front hose to the right length. Also getting the rubber grommets off the stock airbox was a pain in the ass the first time, but now I know how to get them off easily, it would only take a second.
I think I could probably get the car back to stock in 30-45 minutes.
      03-20-2008, 12:24 AM   #12
doba_s
doba_s's Avatar
405
did you try to put stock grey clips back ? I noticed a small cracks inside after i took them off ... and it looks like it can't be installed back ... maybe i am wrong ...
      03-20-2008, 07:41 PM   #13
cn555ic
cn555ic's Avatar
441
Drives: 335i
wanted to know which color springs do you guys have installed?? Yellow or green
      03-20-2008, 09:22 PM   #14
doba_s
doba_s's Avatar
405
yellow on mine ...
      03-21-2008, 09:02 PM   #15
cn555ic
cn555ic's Avatar
441
Drives: 335i
I put in the yellow one of the bat, but wanted to know if there is any significant difference with the green ones...I have not tested this and hope someone can tell me the difference!! I am running 14-15 psi tune
      03-25-2008, 10:20 PM   #16
johnnymu
Warranty Killer
johnnymu's Avatar
Taiwan
126
Drives: Nike shoe
I called and asked yellow or green? the man on the other line said yellow if you have piggyback for ecu.
EUROPROJEKTZ Midwest Member
08 335i Jet Black | too much to name....
      03-26-2008, 09:30 PM   #17
jonerik26
jonerik26's Avatar
Philippines
57
Drives: black 335i e90 PRE-LCI
2007 335i  [8.00]
1998 Acura Integra  [8.50]
2006 325i  [8.00]
for anyone who doesn't get their instructions.....
http://www.forgemotorsport.com/media/FMDVN54.pdf
      04-20-2008, 09:41 PM   #18
T i h o r
n00b
T i h o r's Avatar
88
Drives: 2008 e92 335i 6spd
Thanks man!
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
      04-20-2008, 09:42 PM   #19
T i h o r
n00b
T i h o r's Avatar
88
How in the hell do I remove those gray clips?
I'm dying on that part. I swear my hands are bleeding!
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
      04-21-2008, 08:00 PM   #20
cn555ic
cn555ic's Avatar
441
Drives: 335i
Gloves my man...wear some baseball batting gloves or something...with a glove on its a snap!!!
      11-10-2009, 05:03 PM   #21
ianthegreat
60
Drives: n54
Any DIY w/ working pictures?
      11-11-2009, 04:41 AM   #22
Rubas
Switzerland
Drives: BMW 335xi / KTM X-Bow
Very easy job ..
