Changing to M3 DCT paddles
07-03-2015, 05:26 AM | #1 |
Rep 67
Hi
I have a BMW 335i e92 m sport coupe 2009, 59 plate pre lci, I currently have the ssg paddles and have a dct gearbox, I was looking into getting the paddles changed to the m3 dct paddles and was wondering when i change the paddles would it be plug and play into the m sport steering as some forum post advise they the ssg paddles have 3 clips when the current M3 dct paddles have 2 clips and need ones of the cables to be ground but was wondering if anyone would be able to clarify what is correct Thanks |
07-03-2015, 07:05 AM | #2 |
14
Rep 108
If you have the pre lci m sport steering wheel then it is plug and play. The dct paddle switches do not completely fill the cutouts in the m sport steering wheel but not that it should bother you as the gaps cannot be seen easily. The lci steering wheel requires a small wiring mod. There are numerous write ups on the net. I have fitted the dct switches and extended paddles to my pre lci E91 335i and I'm very happy with the results. Hope this helps.
07-03-2015, 09:45 AM | #3 |
Rep 67
the wiring mod it requires is it to do with connecting one of the wires to earth as the ssg paddles have 3 connection instead of the 2 which the m3 dct paddles have, also does it involve cutting any wires thanks
