Alignment spec
06-27-2015, 06:36 AM | #1 |
73
Rep 811
Alignment spec
When you take your car to request for an alignment done NOT at a BMW, do you just go by how they align it? Or do you have a specific spec that you want them to align it to? negative value on toe.. etc.
I bought the lifetime alignment at Firestone for 189.99, some Firestone claims that they don't have the machine to do it, some say they don't have the techs that know how to do it, some would do it, but said I should really do it at the dealership since BMW would add "weight" to mirror as the car was driving on the road with a person's weight in it. My dealership in Florida charge 199 for a ONE time alignment fee... |
06-27-2015, 06:56 AM | #2 |
65
Rep 222
Firestone is correct in that the car should be loaded with weight prior to alignment. Whether the dealer actually does this or not is another question.
Normally loaded position: 150 lb in each front seat 150 lb center of rear seat 46 lb in cargo compartment full fuel tank Realize the only thing that's adjustable in the front is toe, in which the tools you need are a 13 mm (if i remember correctly) combo wrench and torx bit (i don't remember the size). If you remove alignment pin then you have a tiny amount of camber adjustment, in which you need 13 or so socket and a pry bar. In rear you have adjustment of pretty much everything, only tools required are combination wrenches. Long story short I'd just go to a good suspension shop in your area and get their recommended alignment specs for your driving style. Simon |
06-27-2015, 07:09 AM | #3 |
320
Rep 1,023
An independent shop should still look up the factory-recommended alignment settings and get within those bands, since every car is different as far as optimum settings.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
06-27-2015, 07:56 AM | #4 |
1904
Rep 6,968
The Bentley repair manual has the specs. I would get a copy of them and take it in to a suspension/ front end shop, before you get your 4 wheel alignment.
06-27-2015, 12:10 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
There's no special tools or machine required to align it. The alignment computer will have the specs in their system.
If you're not tracking or trying to fit aggressive wheels, the factory specs is what you should go with.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
