Clutch Issue - Metal Part Snapped?!?!
06-22-2015, 02:21 PM | #1 |
Rep 70
Hi all
I am hoping someone can help! Having just picked up my car today from getting new alloys fitted, I had a weird issue where my my clutch stuck. It suddenly stuck but when I put my foot down to try and change gear, a piece of metal then snapped off and now the clutch is extremely loose. Just shelled out near £1,399 on new wheels and some tyres, please tell me this isn't something too serious? Thanks |
06-22-2015, 02:29 PM | #2 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
Where did you find that lump of metal? In the drivers footwell?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-22-2015, 02:46 PM | #5 |
283
Rep 2,796
Looks like part of the supporting bracket for the pedal assembly(brake pedal/cluch pedal) I could be wrong but the way it's sheared off looks like a stress fracture.
It's tucked up fairly high in the footwell area seen VW's hsve this issue, haven't to be fair seen if it's this a BMW of this age with this issue. |
06-22-2015, 02:57 PM | #6 | |
Rep 70
Thanks |
06-22-2015, 03:03 PM | #7 | |
283
Rep 2,796
http://bmwfans.info/parts-catalog/E9...helper_spring/ I've got no real idea on BMW's re this sort of repair but in the VW's thst have had this issue its about a 2 and a bit hour job partly down to the lack of reasonable access. |
06-22-2015, 03:10 PM | #8 | |
Rep 70
06-22-2015, 03:21 PM | #9 |
Rep 70
Steve, based on your comments, I found this on eBay which refers to the same part number in your picture. Is this what you mean?
http://m.ebay.co.uk/itm/161028803786?_mwBanner=1 |
06-22-2015, 04:11 PM | #10 |
283
Rep 2,796
matty re your car I don't have a clue what model you've got (guessing its a 320d based on the colour pic you've supplied for the breaking car part)but if you look at the circled pic below this is what I though I was looking at so don't take the pic link I placed as 100% guaranteed as I don't know the spec age car you have as its not mentioned.
Re if your's is the right part again diffocult as I don't know the car model you've got as its not stated the pic above isa 320d 2009 model but its a pure guide only based on a hunch but if its in the drivers foot well area its kind of as guilty of being the offending part as a puppy is sitting next to a big pile of pooh |
06-22-2015, 04:24 PM | #11 |
Rep 70
Thanks Steve, loved the big pile of pooh analogy! Yep spot on, my car is a 320d e93 2009 plate. Looking at the part you've circled, I see what you mean now in the top right. I think based on your sound knowledge and the above, you're right as to the problem. What's your advice? Repairable? Safe to drive still?
06-23-2015, 03:39 AM | #12 |
175
Rep 1,596
Looks like the alloy casting of the pedal box itself.
http://www.ebay.co.uk/itm/BMW-E90-3-...item5d590964be I wouldn't be driving it without having done some inspection, you might find the master cylinders just floating around loose being held in place only by its hydraulic line for instance, and continuting to use it could cause more damage. Unless you can get under there and make sure its just the overcentre spring thats come loose, and the spring isnt mashing against anything else. The bracket will probably be mega money from BMW, but theres a couple on ebay for 30-40quid so get one of those and get it swapped out. |
06-23-2015, 03:53 AM | #13 | |
Rep 70
06-23-2015, 04:16 AM | #14 |
118
Rep 3,866
06-23-2015, 04:34 AM | #15 |
Rep 70
06-23-2015, 05:08 AM | #16 |
118
Rep 3,866
06-23-2015, 05:09 AM | #17 |
Rep 70
06-24-2015, 07:35 AM | #19 |
Rep 70
06-24-2015, 08:20 AM | #20 |
283
Rep 2,796
no worries don't forget you've got the appreciate box, in one click you could've saved a few words but glad you've got it under control
