06-16-2015, 06:57 PM | #1 |
463
Rep 957
Destroyed my rear Lca bushings
Well, 3300 street miles, 18 track days, 2300 track miles the rear of my car started to squirm coming off throttle, inspected the rear bushings and there all pretty worse for the wear, the Lca inner and outer bushings are shot.
Anyone know of any Derlin options or cross compatibility? |
08-15-2015, 09:04 AM | #5 |
NewFinishColumbia/detailer
604
Rep 2,096
I thought Dinan made some spherical bearing replacements.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
08-16-2015, 09:49 PM | #8 |
463
Rep 957
Sorry for the delay, been slammed at work. These are rears, so no m3 parts or Dinan kit.
I replaced with some aftermarket ones and also replaced most of the rear suspension with adjustable links with heim joints. so far rear end feels as good as my 13 911 now. |
08-16-2015, 10:20 PM | #9 |
1399
Rep 5,262
what did you replaced it with?
08-20-2015, 09:45 PM | #10 |
125
Rep 356
Holy cow! I'll be checking these now too 😔
12-15-2015, 03:15 PM | #13 |
463
Rep 957
I replaced part # 3 on the diagram with FCM, ironically they are the cheapest and pretty much just solid rubber, which is what I want.
Part #13,11,17 were replaced with Megan racing parts, with spherical bearings. This removed all the flex in the suspension and is much much improved. When you see how much flex is in those stock pieces you would laugh. I know many people are talking about the sub frame bushings, however the arms are still soft. The only other rear upgrade I would consider it the diff bushings, maybe next spring or summer. Car is stiff, but not uncomfortable, can handle semi slick tires now and really I would not want much stiffer for a dual use car. Best way to describe is you def. know where the rear end is, and the traction feel is far better to read. |
12-20-2015, 09:20 PM | #15 |
604
Rep 2,096
Part numbers? That would be helpful for those of us who are looking to do the same thing.
12-22-2015, 03:19 AM | #17 |
1776
Rep 4,511
According to MR website, they do 4 different arms for rear of F series
MRS-BM-0311 MRS-BM-0320 MRS-BM-0370 MRS-BM-0380 http://www.meganracing.com/products/...tid=24&x=0&y=0
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
hoppy6698127.00 |
08-18-2016, 11:47 PM | #19 |
463
Rep 957
tracked the 991 for a few years, little dull. The modded 2r on proper tires is faster and much more of a handful. Consumables are about a 3rd of the cost.
If you go r comps on a 911, you end up with oil starvation pretty quick, engines are pricey on those. 991 has been retired from the stable, replaced with a f type. |
08-21-2016, 09:38 AM | #20 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Also you mention that you replaced the part #3 bushing with "FCM" ... What's FCM?
Ahead of the curve for specF30
08-22-2016, 10:08 PM | #21 |
463
Rep 957
Good, the outer is now replaced with superpro poly, same part number as f30. Just finished swapping out the rear subframe and diff today to poly, should be. Better in general. Surprised at the amount of compliance in those bushings.
x233284.00 |
08-29-2016, 10:43 PM | #22 |
330
Rep 1,084
Which m235i convertible parts did you manage to cram on up front, or is that still a research project?
rwalker@rwalker.com (I really dislike Private Messaging)
