02-13-2008, 08:19 PM | #1 |
348
Rep 2,937
Drives: 2013 Estoril 328i M Sport
My recommendation for a USB flash drive
I started another topic a while back asking about what a good choice for a USB flash would be. After a ton of research, I settled on the Corsair Flash Voyager 8GB. I've had the unit for about three weeks now and can give a brief synopsis of its overall quality.
It's encased in sturdy and firm rubber padding. Tests have shown that you can run it over and it'll remain in pristine quality. This is unlike many earlier USB flash drives that were in normal plastic housings that could break without much harassment. The unit I bought in particular is the 8GB version, which holds roughly 1,300 songs in 320kbps quality. A main factor in considering a flash drive is it's read speed, and the Flash Voyager is the fastest unit on the market (outside of its more expensive brother the Flash Voyager GT). It's average read speed is 38 mb/s, which is a great deal faster than other drives that average around 8 mb/s. Even if you're sending FLAC quality songs through your amp, there won't be any lag time in requesting the song and it appearing through the speakers. The MAJOR plus in running a USB flash drive instead of your iPhone/iPod as the provider of your MP3s is that iPhones/iPods are the utility that process the audio signal and they do it in analog only. Flash drives on the other hand don't do any of the processing at all and hand that task over to the unit installed in your car which in turn does it digitally, thus giving a more pristine representation of the original MP3/WAV's quality. The Voyager comes with a USB extension cable that allows you to clear the height restriction in our tiny armrests. Overall I think this is the ideal piece of hardware to use with the iPod adapter that many of us will be getting. If anyone's interested, Newegg has a good deal on it: http://www.newegg.com/Product/Produc...82E16820233037 |
02-13-2008, 08:35 PM | #3 | |
348
Rep 2,937
EDIT: It should be known for those that are unaware that Corsair is one of the leaders in the low latency, high speed PC memory market alongside OCZ and Patriot. Their reputation in providing stable and fast memory is second-to-none, so that's another plus to consider. |
02-14-2008, 02:28 AM | #4 |
24
Rep 438
That's an excellent drive.
Last year I bought a 4gb Patriot drive similar to that one - for the same reasons. It was by far the quickest drive on the market for read and write speeds - works like a charm to this day. It's also in a similar rubber casing which is a HUGE plus, feels so much more durable than other plastic drives I have. they make a 16gb version of that exact drive too http://www.newegg.com/Product/Produc...82E16820233042 |
02-14-2008, 07:28 AM | #6 | |
135
Rep 1,274
02-14-2008, 12:14 PM | #7 |
348
Rep 2,937
02-14-2008, 02:43 PM | #8 |
34
Rep 330
in a 320D today I tested a CD, Flash drive & ipod. My self and someone else couldn't tell the difference in quality between the 3 different sources, this was on the base euro sound system though so you might hear differences on the higher end systems.
I'd take it with a pinch of salt though until someone does some proper double blind tests, the line out using the dock connector of an ipod is pretty good, most people compaining about poor ipod sound quality are probably playing dodgy 128kbs mp3 downloads |
02-14-2008, 04:30 PM | #9 | |
348
Rep 2,937
