advice please
06-15-2015, 08:37 PM | #1 |
Rep 40
advice please
why is it that my car is throwing codes 2fd2, c7e2, c2c2 when I had my jb4 installed ( got codes from laptop ) with just bms dci, but when I removed the jb4, all codes and SES light disappeared and car drives normal? Also i still haven't figured out what those codes means. I really wanted to install jb4 again but I'm afraid my car will give me more problems. advice?
2fd2, c7e2, c2c2 are codes from usb cable thru laptop. p114b and p114d are codes from OBD from autozone. |
06-15-2015, 08:42 PM | #2 |
96
Rep 1,031
Drives: 335 E92 DCT
did you install it properly?
Google those codes as it will give you an idea of what each codes mean. Do you have DPs? because they will throw some codes at you which is normal, but the JB4 will auto clear those when its active (not 0/0 inactive) can't remember what those codes are.
Certified Australian
06-15-2015, 08:52 PM | #3 | |
Rep 40
06-16-2015, 09:46 PM | #5 |
Rep 40
I replaced 6 new plugs and 2 coils couple of months ago. codes and SES light came on after I did a few WOT, started jerking and hesitation since then. Do you think it has something to do with my injectors since O2 is ok?
06-16-2015, 10:23 PM | #6 |
74
Rep 718
Did you fully remove the JB4? It would be interesting to see if it runs OK on MAP 0 (Stock). I think you will have people tell you that it sounds like coils, or maybe the injectors.
06-16-2015, 10:32 PM | #7 |
Rep 40
Car is my daily driver, I didn't want anymore problems so I fully removed it and installed again twice, same issue. I tried running map0 stock but problem still occurred. So as of now it is completely stock. Jb4 issues?
06-17-2015, 09:26 AM | #8 | |
44
Rep 23
Yes JB4 issue or how you installed it... |
06-19-2015, 12:46 PM | #11 |
Rep 40
06-19-2015, 01:20 PM | #12 |
74
Rep 718
06-19-2015, 01:29 PM | #13 |
97
Rep 282
Did you buy the JB4 new or used? If new just call BMS. If used, it may be worth checking to see that the wires in the harness are all correct since the person may have upgraded from a JB3/JB4.
JB4 (G4)> JB4 (G5) http://www.n54tech.com/forums/showpo...57&postcount=1 JB3>JB4 (G4) http://www.n54tech.com/forums/showpo...82&postcount=1 |
