F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > depinning the flex fuel wires from a JB4 harness
Extreme Powerhouse
      06-15-2015, 04:57 PM   #1
G30 B58
Pace Car Driver
1548
Drives: '22 AW G30 B58 M-Sport
Question depinning the flex fuel wires from a JB4 harness
I know this is really a question for N54Tech but has anyone removed the flex fuel wiring from the JB4 harness? Either by de-pinning or by cutting the wires and insulating the exposed copper within the split loom.
Reason being, I'm never gonna use the flex fuel (too hard to find) and I just wanna clean up the harness. I know this will kill my resale value but buying another harness is always an option.
I'm over-thinking this, aren't I?
      06-19-2015, 12:26 PM   #2
Earthmaster
127
Drives: 15' M4 Austin Yellow
Tape it with electrical tape to cover it?
      06-19-2015, 02:09 PM   #3
G30 B58
Pace Car Driver
1548
I was told on "the other forum" (BMS) that with the EWG and the flex fuel wiring and my mods, it would be to my advantage to use the flex fuel and the EWG wiring.
The reason for FF wires when using EWG wires is to allow JB4 to control fuelling to keep air:fuel ratio within safe limits.
If running higher boost targets without JB4 controlling fuelling then your car may run too lean in which case either jb4 fail safe will kick in and or DME starts to pull timing and boost or goes into limp mode.
      06-19-2015, 11:03 PM   #4
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
24199
Drives: 07-335/12-328/18-M4/21-M4CP
Yes you are
Just wire it even if you are not going to use it.
https://x-ph.com/sale/
Phone number 702-494-9435
f30post
