06-14-2015, 10:18 PM | #1 |
Rep 44
which header should I choose?
Hi guys
just got my 435 last month. Mine came with MPPK, however I still find the sound not so satisfying I heard (if I'm wrong, please correct me) one can simply change the header to make the sound much better? Since I would like to keep the mp exhaust pipe on the car, so if I can only install the header it would be perfect and save me a lot of money. if that's the case, what would you recommend? A friend of mine told me to install an ER for N55, but I don't wanna make hurry decision. thx a lot |
06-14-2015, 10:47 PM | #2 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
there are no aftermarket headers for our cars, we have a turbofold, turbo and header are all once piece. You can however get a new downpipe, catless or high flow cat, and that will help with sound, and with a jb4 it will give you even more power
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
06-15-2015, 04:35 AM | #3 |
1779
Rep 4,516
I have HFC DP on my car - adds more volume and character to the exhaust w/o droning. Allows high boost on mapped/piggyback enabled cars......
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
06-15-2015, 05:52 AM | #4 |
Pace Car Driver
1548
Rep 3,164
We love all the audibles our Shiftek catless DP gives us and you get to retain the OEM look out the back.
Of course there is the CEL one must deal with with this set-up, JB4 is a must to take full advantage. |
06-15-2015, 10:43 AM | #5 | |
BimmerPost Supporting Vendor
4918
Rep 115,980
The downpipes will definitely make the exhaust sound much deeper and throatier. Its a great sound! Mike |
06-15-2015, 10:54 AM | #6 |
515
Rep 1,063
Challenge makes one, but i wouldn't piss on them if they were on fire. Terrible company and worst customer service in the world. Not to mention the HFC core melted on my downpipe. I sent it to them for a replacement/refund 6 months ago and I have to get a response from them after multiple emails
A lot of folks have ER downpipes and Ive never read a negative comment about it so thats a good option. I have CG Precision, they make their own custom catless downpipe that matches up with their exhaust so you can have a true full 3.5" exhaust all the way through without the downpipe creating a slight restriction. Theres a couple more options out there, so do your research before you pull the trigger.
06-15-2015, 11:57 AM | #9 |
210
Rep 1,161
All things being equal, I prefer to replace the metered cat-back exhaust instead of the downpipe, especially if your goal is a better sound. When you replace the cats (or remove them) with all but the best catalytic converters, you're asking for headaches.
06-15-2015, 12:02 PM | #10 | |
Pace Car Driver
1548
Rep 3,164
06-15-2015, 01:45 PM | #11 | |
24201
Rep 190,807
If you are planning on adding a Jb4, get the downpipes. It will get you a sound upgrade and performance gains. Evolution Racewerks DP are the most popular. VRSF is another good option. If you do not wish to get a JB4, catless downpipes will trigger the CEL light and will not pass emission so grab an axle back instead. Active Autowerke, Remus are very good options.
06-15-2015, 02:04 PM | #12 | |
4918
Rep 115,980
Mike |
06-15-2015, 02:07 PM | #13 |
24201
Rep 190,807
The BMS Canflap works as well
06-15-2015, 03:23 PM | #14 | |
Rep 44
I am abt to ask around to see if it's available. thx a lot |
06-15-2015, 03:32 PM | #15 | |
Rep 44
btw, I was toldt that it might be a bit stink if a catless dp is installed. is that true? thx |
06-15-2015, 03:38 PM | #16 | |
24201
Rep 190,807
Catless downpipes will give you more power, better sound and with the Jb4 installed no need to worry about the CEL code. the JB4 + DP combo is a great choice for maximum power.
06-15-2015, 05:01 PM | #17 | |
515
Rep 1,063
JB4 does work on top of MPPK
06-15-2015, 10:27 PM | #18 | |
Rep 44
Just notice you are from GTA as well. So is ER downpipe for 435 ok in toronto? I'm not quite sure about the smog check requirement here(fresh of the boat) |
06-15-2015, 10:28 PM | #19 |
Rep 44
thx a lot! sounds pretty tempting
06-16-2015, 08:25 AM | #20 | |
4918
Rep 115,980
The JB4 will also work over the PPK as the PPOK is pretty mild. Mike |
06-19-2015, 09:18 PM | #21 | ||
Rep 44
Will think about it
Current: 2015 435 Xdrive(Canada)
Acura TSX(China) Previous:2011 Z4(California) |
06-19-2015, 11:05 PM | #22 |
515
Rep 1,063
well Challenge finally came through and sent me a brand new HFC downpipe lol that i have no use for
