Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Rear passenger tire rubbing
      06-14-2015, 07:41 PM   #1
Joe36
Drives: 2011 328xi
Hey guys, im having a problem with my rear passenger tire rubbing on my xi. It's not lowered, no fender roll and no spacers . I have 18x9 33 offset with 275/35/18s it only rubs on the rear passenger side when going over slight bumps and some turns...other side has no problem. I just got these new tires and wheels put on this week..so I can't replace them.. help me out please and thanks in advance!
      06-15-2015, 09:20 AM   #2
Gary@TireRack
Moderator
Gary@TireRack's Avatar
369
Drives: Formerly 1995 M3
The sizing is a bit too aggressive. Unless you can get the fenders modified, you'll be looking at tires in 265/35R18 or 255/35R18 instead.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      06-15-2015, 10:01 AM   #3
brewnami
100
Drives: 2009 BMW 335i M Sport Coupe
Do you know the camber specs? Seems odd that if all things are equal, you'd be rubbing on one side. Many people on here run 275s. Either adjust the camber in slightly or roll your fenders a little.
      06-15-2015, 01:02 PM   #4
Joe36
Drives: 2011 328xi
Thanks for the replies guys. I can't change the tires..so I'm gonna look into getting the fenders rolled. I'm not familiar with camber specs.. is it something with alignment?
      06-15-2015, 07:44 PM   #5
brewnami
100
Yes, negative camber will position the top of the wheel to tuck in a little bit. Depending on the angle, it can help with handling as well. I think factory specs go up to -1.7 in the rear. You won't need to worry about tire wear at that setting as long as your toe angle and thrust angles are on point. Any decent tire shop could help you out.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
      06-16-2015, 12:27 AM   #6
bmw325i
223
Drives: 2006 BMW 325i
+1 a little bit more negative camber will probably fix it. One side might have more camber than the other just enough that it rubs.
      07-10-2015, 04:18 PM   #7
e92dropped
e92dropped's Avatar
Drives: e92 08 335i
seems like that rear passenger shock may be going bad
      07-13-2015, 02:43 PM   #8
Momukhamo
Philippines
25
Drives: 2009 335i xdrive
i had 275/35 18X10 I with camber and still rubbed.
275 is too wide for lci e9X
i replaced them with 265/35 and got rid of the rubbing.
