GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      06-13-2015, 11:31 PM   #1
volkl23
46
Drives: 2018 F80 M3 ZCP
Can someone please tell me what I'm doing wrong with my coding?
Hey guys,
I followed all the directions from Shawn's guide and was able to get the connection with the car through VIN and everything looks fine.
I followed the directions and was able to get to the step where you actually edit the FDL file, but when I actually try to code something, I can't find any of the functions:
As you can see, I don't see any function names and when i dive deeper into the structure, they are all dots.
I'm using 3.24.3 with PZdata lite.
What I am doing wrong?
Thanks in advance!
      06-14-2015, 12:52 AM   #2
volkl23
46
I'm using the latest version of the Esys Launcher (2.07).
I did notice that the car series reads F999 and I can't change it. Is it not reading the type of car correctly? Should it be F20 for the f80/82/83?
      06-14-2015, 08:51 PM   #3
sleepy75
106
Drives: Honda Civic
I know it's not much help but I do remember being able to select F80 in the launcher.
      06-15-2015, 10:17 AM   #4
volkl23
46
I figured it out (i.e. Shawn sent me the solution ). If anyone is having the same issue, just change your computer system date to 4 days in the future. When you do that, you should be able to select the car series on ESYS. When you're done coding, just switch back the date.
      06-15-2015, 05:34 PM   #5
DaBean
Sakhir Smurf
314
Drives: Plaid, F82 M4, E46 M3, Sequoia
2002 BMW X5 4.4i  [0.00]
2015 BMW M4  [0.00]
2004 BMW M3  [0.00]
?? That seems like a strange fix. What's the rationale behind doing that? I'm not debating the fix, just trying to understand it...
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads
NASA NorCal Instructor
      06-15-2015, 05:54 PM   #6
volkl23
46
No idea, but it worked after that small hack. Before, under the car selection, it would default to F999, but after changing the date, I was able to select F80 which decoded all the truncated values.
f80post
