Wheel balancing weights panic help!
06-13-2015, 02:27 PM | #1 |
79
Rep 1,009
I usually always clean my wheels by hand but was in a rush earlier and hit them with the karcher. One of my wheel balancing weights got blasted clean off! I've never heard of this happening before.
I've got a long journey to do tomorrow, what would you recommend? Is sticking the weight back on with double sided sticky tape a stupid idea? Will I cause any damage if I run the car for a couple of hundred miles without the weight tomorrow and until I can get it booked in? Tips appreciated! Many thanks!!
Ess
2009 E92 335d M-Sport 1990 E30 2.8 m52b28 conversion |
06-13-2015, 02:59 PM | #2 | |
6659
Rep 15,858
BTW, I've had a weight or two fall off winter wheels when cleaning them after winter use. Stuck them back in place, no issue with balance. HighlandPete |
06-13-2015, 03:49 PM | #4 | |
79
Rep 1,009
Thanks man, appreciate the input!
Ess
06-14-2015, 06:33 AM | #5 |
31
Rep 316
No need to panic - if you drove without a weight you might not even notice and if you did the worse you would feel would be a little vibration at certain speeds.
06-14-2015, 10:48 AM | #6 | |
79
Rep 1,009
Panic over! Thanks all |
06-15-2015, 06:56 AM | #7 |
Rep 313
As others have said, taping back on is fine but it's a five minute job for any number of tyre shops like Kwik Fit so if there's one near you I'd just drive up on the off chance that they will sort there and then
06-15-2015, 02:01 PM | #8 |
79
Rep 1,009
Thanks buddy! I'm going to take this opportunity to buy some nice silver wheel weights which will be less visible on my wheel and then get them all rebalanced and replaced
06-18-2015, 04:03 AM | #9 |
136
Rep 5,050
Get yourself a set of Bluetooth weights, you can keep them in the glove compartment and they won't spoil the look of your wheels
06-19-2015, 12:57 PM | #10 |
79
Rep 1,009
