Photography: Tips Thread
02-12-2008, 03:21 AM | #1 |
275
Rep 9,218
I'm a total novice when it comes to photography.
Reading through Viv's thread about choosing a DSLR camera and having seen some of the images posted by people on the forum suggests that we have some really knowledgable and talented photographers out there. So I thought a general discussion about improving ones photo skills might be interesting. I'll start of with a question or two ... I have a cheapish 'ultra compact' point and shoot camera, which I bought a couple of years ago: http://www.cameras.co.uk/details/cas...im-ex-z750.cfm It can produce some really great images outdoors where light levels are high, but interior shots tend to be less crisp, with a bit to much digital noise in the shadows. Is that just indicative of the quality of the camera (ie do I need an SLR to do any better) or is there something I can do to improve my shots? This photo is one of the nicest I have managed to take with the camera, but how could it have been better? Last edited by NFS; 02-12-2008 at 12:29 PM.. |
02-12-2008, 10:11 AM | #2 |
Techie Geek
37
Rep 681
Noise is a function of the capability of the sensor (be it CMOS or CCD) to "collect" light. Basically the smaller the photosite the more noise is produced.
Now a P&S has a 1/4" ~ 2/3" sensor, if you compare that to an APS-C sensor seen in most dSLR's or the full frame sensors in Canon 1 and 5D bodies or the new Nikon D3 and you see why 10 megapixels in the available area is an issue for a P&S. Bob Atkins has a nice article on this: http://www.bobatkins.com/photography...e_matters.html A dSLR would of allowed you to add a haze (UV or Skylight) filter to that shot to help reduce some of the softness. Although personally I'd of gone with a circular polariser to give the sea a bit more blueness and bring out the greens in the landscape more. This is probably a similarly hazy day:
330d M-Sport | Sapphire Black | Black Dakota | Nav Pro | iDrive | Bluetooth | PDC | Xenons | Hot Seats | Tracker | Blacklines
02-12-2008, 10:46 AM | #3 | |
275
Rep 9,218
So the 'noise' I struggle with on internal shots is because I am limited by the size of the sensor and lens, regardless of the number of megapixels detected by the sensor? Is this also why the external shots are better than internal (more light), but not as sharp as with a DSLR? |
02-12-2008, 10:57 AM | #4 |
Techie Geek
37
Rep 681
Well, it's the race for MORE megapixels that's effectively causing increased noise in P&S cameras. If you think about it, the sensor size doesn't increase so cramming 10 million pixels into the space that had 7 million effectively reduces the size of the photo sites dramatically.
You can obviously only get a finite amount of light INTO the lens and the electronics need a certain amount given their sensitivity. Diminishing returns at work really!
02-12-2008, 11:10 AM | #5 |
Techie Geek
37
Rep 681
Ok, I found the article I was looking for!
This might help: http://www.sphoto.com/techinfo/dslrs...slrsensors.htm I know the conclusion doesn't ring true with the theory but you'll at least understand why a P&S has so much trouble with noise.
02-12-2008, 03:49 PM | #6 |
34
Rep 330
Photography also seems to be easily seperated into two subjects,
1. Taking the photo 2. Post processing Most of the great pics you see around have probably had some heavy PP done in photoshop etc. in addition to good cameras/technique For indoor shots a compact is never going to perform well, firstly the amount of light that is let into the lense is small so the onboard flash fires but creates harsh light shadows etc. The first think you can do to improve pictures indoors is to use bounce flash off the roof etc. Or you can invest in a DSLR and use a lense with a very wide apeture called a prime which will allow enough light into the camera without using the flash. I spent two mins on your photo, do you like this better? |
02-12-2008, 04:57 PM | #7 |
147
Rep 5,080
Drives: 530d
Digital allows you to do three things that film doesn't
1. Get instant feedback from the LCD on the camera. 2. Take as many pictures as you can without worrying about processing cost. 3. Develop your image manipulation skills. As Garry says, you can spend more time editting a shot after it has been taken than taking it. Once you are more familiar with what you can do in the "digital darkroom" you can get a lot more out of your shots. My take on your pic, just a bit of levels correction applied just to the upper half of the picture and a little saturtion boost.
Gone: Fiesta - Focus - E46 320dSE - E91 330dMSport - E82 135iMSport - R55 JCW Clubman - M135i Now: 530d |
02-13-2008, 01:28 AM | #8 |
Techie Geek
37
Rep 681
This brings up another point actually. A dSLR will let you shoot in RAW format, meaning that you have access to exactly the image the camera recorded as opposed to a processed JPEG. This gives you far mor control over any post processing and allows you to make the most of the image.
This shouldn't be at the expense of getting it right in the camera in my opinion though.
02-13-2008, 03:57 AM | #9 | |
652
Rep 3,445
Drives: G22 M440D
Most cameras enable the saving of a RAW file alongside a normal JPEG - at the expense of taking up more space on your memory card (but with cards being so cheap that is hardly worth bothering about). I bought my 400D to mainly create HDRs ... D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
02-13-2008, 10:34 AM | #10 |
Rep 24
Something else to take note of is the ISO setting on the camera. Typically many compacts use an AUTO ISO feature or set it artificially high. ISO is a measure of how sensitive the film/sensor is to light. In brief, a high ISO number (eg 1600) will be very sensitive to light so the shutter speed can be faster but at the expense of noise. A low ISO (100/200) will have less noise but requires a slower shutter speed.
Many of the automatic features of compacts (night-mode, sport mode etc) will adjust the ISO and set the "perferred" priority on either shutter or aperture. Have a look at your camera and see if you can manually overide the ISO and see if that improves the situation HTH |
02-13-2008, 12:48 PM | #11 |
571
Rep 7,519
Drives: 2009 E90 335i MT
I saw a 1GB compactflash card yesterday that was less than 1/16 what I paid for my 1GB microdrive (5 years ago). Oddly enough, alongside it was an 8GB that was more than half of the microdrive.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
02-14-2008, 06:59 AM | #12 | ||
275
Rep 9,218
I read about 'bracketing' recently - taking multiple versions of the same shot at different settings - and have been playing about with it a little. I've also just discovered that my camera has a digital 'flash assist' which enhances the shadows and highlights on flash images, to provide the impression of additional lighting. Activating it has definitely improved the sharpness of indoor shots. I am also contemplating using the manual settings for shutter speed. Sometimes with the auto settings the selected speed isn't that quick and we have noticed some images with faint blurring that's visible when zooming in. |
02-14-2008, 07:16 AM | #14 |
147
Rep 5,080
Drives: 530d
Been there and wondered who turned the lights out!
02-14-2008, 02:28 PM | #15 | |
34
Rep 330
you'll need either a camera with bigger apeture or you need some external light source like a flash |
02-15-2008, 03:03 AM | #16 | |
275
Rep 9,218
I think this may be the main reason why the camera is better in bright light. |
02-15-2008, 03:11 AM | #17 |
34
Rep 330
Yeah, to give you an idea I've only been able to get reasonable indoor photos using available light with my DSLR and a prime lense open to about f1.8, anything smaller and I need fill flash as well.
02-16-2008, 07:29 AM | #18 |
40
Rep 1,167
Drives: Audi RS5 Sportback Carbon Blac
Here is a wee photo taken with my point and shoot Olympus Miu digital. I have never posted a pic before and just wanted to check how to do it before I get the new e92 as I will be posting pics asap!!! Edit: okay, so the photo is there - what do I need to do to adjust the size of the photo as this is massive? |
02-16-2008, 07:50 AM | #19 |
THE Viv
185
Rep 4,743
Drives: 330i SE
Very little work using the unsharp mask will work wonders- I've purposely overdone it, just to show you the difference
Any graphics program will let you reduce the pic size down. There are some simple & easy-to-follow Photoshop video tutorials available here. Viv |
02-18-2008, 11:06 PM | #21 |
697
Rep 7,308
Drives: see above.
02-19-2008, 08:23 AM | #22 | |
275
Rep 9,218
