Oil Filter Housing Gasket - Tool
06-05-2015, 04:13 PM | #1 |
1208
Rep 2,835
I did this a few months ago and had a PIA time getting to the bolt behind the manifold.
I started looking around for something simplier and came up with this..... Craftsman 1/4" socket # 33084 - 8mm Craftsman 1/4" knuckle Craftstman 1/4" Extension # 43531 Fits perfectly between the housing and the manifold. Hope it helps.... |
06-07-2015, 03:54 AM | #2 |
Member
30
Rep 115
Drives: Metallic Black 2006 325i
Agreed that is the tool to use, however e-torx 10/12 socket instead of the regular socket.
Fly the BMW.
06-07-2015, 08:42 AM | #3 | |
1208
Rep 2,835
Socket is in Craftsman Set #32824 Last edited by Greyfox; 06-07-2015 at 12:10 PM.. |
08-15-2015, 07:12 PM | #4 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
Another alternative...
http://www.amazon.com/GearWrench-922...orx+box+wrench i used this tool, as described here:http://www.e90post.com/forums/showpo...4&postcount=91 , after stripping one of the bolts using an 8mm. |
mweisdorfer1902.50 |
08-15-2015, 07:30 PM | #5 | |
1208
Rep 2,835
08-19-2015, 01:46 AM | #6 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
Thank you. It's members like you that add value to this community.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
06-26-2017, 01:45 AM | #8 |
21
Rep 115
Drives: 2011 535i (6sp)
I actually had success with a 5/16" Craftsman Ratcheting Wrench! I locked onto the bolt and had the wrench stick out toward the front of the engine bay in between the clip wiring harness (removed) and the first plenum of the intake manifold. Keep in mind this was on an N52 (2006).
07-02-2017, 08:11 AM | #9 |
480
Rep 1,600
If you're using a non-reversible ratchet spanner, crack the bolt loose then unscrew the bolt with your bare fingers. Or the bolt and spanner will be pushed up against the coolant hose fitting which is fragile on removal.
Inspect your drive belt and all surrouding rubber hoses for swelling before commencing the job - the leaked oil may have damaged the rubber, causing it to swell. You might need a top hose, hose to the head, and a drive belt and possibly pulleys if the belt had been slipping and melted the plastic pulley(s) |
07-02-2017, 03:23 PM | #10 |
Cometh
1090
Rep 1,308
Drives: Boy's Soul
Was the bolt in question over-torqued for anyone else? I tried to remove it using an 8mm 1/4" socket and the bolt started stripping. I also tried an 8mm ratcheting wrench but the bolt wouldn't budge.
07-02-2017, 05:29 PM | #11 | |
1208
Rep 2,835
Don't know if it matters, but I had let my car sit overnight before working on it. |
07-02-2017, 08:42 PM | #12 | |
Diamond Geezer
212
Rep 2,385
07-04-2017, 04:18 PM | #13 |
1208
Rep 2,835
It's not a standard 8mm socket. They are the Craftsman 16pt sockets.
07-09-2017, 09:45 AM | #14 |
21
Rep 115
Did you try to ladder the wrenches (giving more leverage) by using another box end wrench connected to the open end side of the ratcheting wrench?
07-09-2017, 09:09 PM | #15 |
4276
Rep 9,209
Next time use proper socket. Is inverted torx. No 6, 12 or 16 point 8mm
09-11-2018, 06:44 PM | #16 |
24
Rep 213
just unscrew the manifold a little and pull it out of the way, takes an extra five min, you are thinking too much into this, and the bolt it long it hits the manifold and you have to move it anyways
