2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Squeak front right wheel area, need some more advice.
      06-03-2015, 10:10 AM   #1
deeslk
12
Drives: 15 M235, 11 E90 335i M-Sport
I have what sounds like a plastic type squeak on our new M235. The sound increased in frequency and a bit louder with increased rotational speed. Stock suspension OEM 624M wheels. I took the wheel off nothing appears to be rubbing and no stones etc in the tire. It almost sounds like the squeak on a basketball court with shoes.
If you can have a listen at the 7 second and 11 second mark. I will take the wheel off again and have a look but not sure where else to lool.
Also it only happens when the wheel is straight and not on turning. I read a lot about some suspension related squeak on turning.
Audio Clip.
https://clyp.it/udmhtdac
Thanks
      06-03-2015, 10:18 AM   #2
overcoil
3069
Drives: M235i 6spd
Turn the wheel tire assembly with the engine off. Then turn brake disc by hand engine off. If noise only happens w/engine running could be ABS - example guess.
      06-03-2015, 10:54 AM   #3
pikcachu
pikcachu's Avatar
1398
Drives: M235i (F22 Red angel)
lol sounds like a clicker wrench
maybe there is a monkey in the engine
      06-03-2015, 12:47 PM   #4
deeslk
12
Thanks I will give that a try.
      06-03-2015, 06:41 PM   #5
deeslk
12
Ok I tested this, hoisted the car up, with the car off I spun the wheel no clicking noise. So you think it could be related to the ABS?
      06-03-2015, 09:17 PM   #6
overcoil
3069
Drives: M235i 6spd
does sound electrical so ABS is just an ignorant guess.
I'll chk my car for the noise - could it be a diagnostic self test -
      06-09-2015, 07:07 AM   #7
deeslk
12
The squeak ended up being related to the manufacturer ticker that was left inside the tire, it was near the bead of the tire. Took a few hours to get to the root of the problem. They took apart the breaks first before moving onto dismounting the the tire. Thanks for all the help.
      06-09-2015, 08:10 AM   #8
overcoil
3069
Drives: M235i 6spd
STICKER ?
That's funny.
But reassembling the brakes was the right thing to do. I once had a similar complaint on a Mercedes and the dealer wouldn't pull the pads to check - I did the work and it was a misaligned pad.
Search this Thread:
Advanced Search
2addicts
