BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > K&N Drop in Filter
      02-11-2008, 02:29 PM   #1
wuufer001
wuufer001's Avatar
Taiwan
375
Drives: 2006 E90 M/T
2006 325i  [9.34]
K&N Drop in Filter
i just replaced my stock filter with the K&N drop in but didn't remove the charcoal filter. will just replacing the filter (kept charcoal inplace) give even the slightest difference that a person driving can notice? i read about removing the charcoal filter thread but don't know if its good for the engine or not cause i think they placed it there for a reason, but if removing the charcoal will make a even GREATER difference then maybe will think about it.
i know many of you will say Intake FTW but i think i will do the drop in first and see how it goes.
anyone that has either replaced the stock filter and/or removing the charcoal filter too please feed me with some input. thanks
(everything here is about stock intake)
      02-11-2008, 03:50 PM   #2
323d
323d's Avatar
Hong Kong
52
Drives: 335i E90
you will mentally think is louder and faster for the first week since you will be more focused on trying to hear for the change in sound of intake.. but infact it will do nothing.
ZSP susp//18's 550i reps//blacklines/aftermarket grill//
      02-11-2008, 04:13 PM   #3
sparkyg
sparkyg's Avatar
142
Drives: A6 Allroad
Charcoal filter - air intake for passengers
K&N - air intake for engine
Edit: I did some reading. I found the filter on the airbox. BMW sure goes all
      02-12-2008, 04:32 PM   #4
alex2112
26
Drives: 2016 X1 M-Sport
You most likely won't feel anything. The only way you might see a SLIGHT difference is maybe gas mileage?
      02-12-2008, 06:40 PM   #5
xdrive
20
Drives: 330xi
Shouldn't you be asking yourself that question as to whether you notice a perf. difference?
You changed the filter in your own car. So how does it feel? No difference?
      02-13-2008, 10:51 AM   #6
d3l0n
I love the ///M3, but I want 550hp ///M5
d3l0n's Avatar
141
Drives: BMW330iE90
slight, and only at higher speeds
      02-13-2008, 11:56 AM   #7
scanboy
16
Drives: E90 Montego Blue+Black Int.
I removed the charcoal filter, but didn't replace the original air filter.
I can tell you I don't regret removing it as the difference is quite noticeable.
You will find that engine runs smoother than before at rpm < 2k.
I just did this last weekend, so I'll have to monitor the MPG for a bit, but I need to adjust my driving cause the engine reaches above 3k rpm faster, and I often forgot to up shift until it reaches 4k rpm (I'm not a high rpm driver).
      02-14-2008, 12:23 AM   #8
wuufer001
wuufer001's Avatar
Taiwan
375
2006 325i  [9.34]
any one also remove the charcoal filter and have any problems? i'm kinda getting paranoid after removing the charcoal filter
      02-14-2008, 12:55 AM   #9
kpxshorty
35
Drives: 2008 E90 335i
so if you remove charcoal filter, you will get better gas mileage?
      02-14-2008, 09:59 AM   #10
sejoon85
sejoon85's Avatar
20
Drives: AW e92 m3
Sorry for the newbie question, but what is a charcoal filter?
Dont we just replace the oem drop filter with the stock filter?
The 2 mins procedure?
      02-14-2008, 10:19 AM   #11
T i h o r
n00b
T i h o r's Avatar
88
Drives: 2008 e92 335i 6spd
I'm just as lost as you bro.
What's all this talk about filters and what not?
      02-14-2008, 10:35 AM   #12
bebecker
Drives: 2006 330i 2007 335i
The confusion is because there are two charcoal filters. One charcoal filter for the cabin, this is replaceable, which is separte from the engine air filter. The second is behind the replaceable engine air filter in the factory intake box, this filter I believe was intended to be permanent. However, people have removed this charcoal engine air filter. Check DIY for details. This filter appears quite restrictive. I have removed it, but ended up going with a Simota in the end.
      02-14-2008, 03:26 PM   #13
Phil325
Phil325's Avatar
15
Drives: 06 SGM E90
2006 325i  [10.00]
whats a simota
work in progress..
      02-14-2008, 03:26 PM   #14
Phil325
Phil325's Avatar
15
Drives: 06 SGM E90
2006 325i  [10.00]
nm. its an intake.
work in progress..
      02-14-2008, 03:35 PM   #15
uabimmer
Україна
uabimmer's Avatar
Ukraine
24
Drives: JB e90 330i
2006 330i  [0.00]
2003 330i  [0.00]
I removed my charcoal filter and still have my stock air filter.
There is a noticable difference in the way the car breathes but I dont know if a can say its faster.
BTW I'm getting 21mpg-mostly city driving (and pretty spirited)
IN THE PASSING LANE - e90 330 JetBlack / 6000k D1S / 40% all around / LED Lic.Plt. / LED reverse lights / 7500k Fogs
      02-14-2008, 04:09 PM   #16
Mattscott
Mattscott's Avatar
108
Drives: 2007 335i E90
Does the 335 have a charcoal filter? I just opened the air box, and only a drop in filter. I didnt see a charcoal sheet anywhere.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      02-14-2008, 04:24 PM   #17
e90AW335i
137
Drives: e90 335i
nope, I dont believe we do....
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote.
      02-14-2008, 04:30 PM   #18
Mattscott
Mattscott's Avatar
108
I was all ready to DIM (do it myself) and remove it today. I guess now I'll paint the exhaust tips black
      02-16-2008, 09:14 PM   #19
xdrive
20
Drives: 330xi
Is the 21 mpg before the charcoal filter removal or after?
