335D Owners - Which oil are you using?
05-31-2015, 11:30 AM | #1 |
99
Rep 477
Hello All
For those who have a 335d, which oil do you guys use? an is your D remapped or without a dpf? Regards
Follow My e92 335 AW- SNOW WHITE PROJECT BUILD
http://www.e90post.com/forums/showthread.php?t=952654 photo uploading websites |
05-31-2015, 04:43 PM | #6 |
99
Rep 477
Ow wow, so no one with a mapped 335d is using 0w40 or even 0w30?
05-31-2015, 05:12 PM | #7 |
175
Rep 1,596
What do you think would be achieved by switching to an 0w oil?
0w oils are slightly thinner when cold compared with a 5w, but thats it, it makes no difference once at operating temperature. |
05-31-2015, 06:25 PM | #8 |
99
Rep 477
I was told by my mechanic to use mobil 1 0w40, where as usually i would use thr 5w
06-01-2015, 04:13 AM | #9 |
662
Rep 1,239
yeh it never gets that cold to justify a 0w tbh
normally you tend to go up in viscosity (even a word? lol) when you start tuning things due to the extra heat that normally comes hand in hand with more power , hence my reason to wanting to maby hop up from 5w30 to 5w40 good brand oils do out perform the cheap ones in hard use , that said there's nothing wrong with comma oil for day to day driving , key is to have regular changes , track use is slightly different again due to the temps the oil will get and break down that occurs (once oil is burnt its bin material) castrol/mobil/motul/millers and anything with a good ester is normally what i stick to but everyone's diffrent |
06-01-2015, 06:29 AM | #10 |
99
Rep 477
Thanks jack!
Would you recommend for me to go ahead with mobil 1 0w40 or 5w40 like you said?
06-01-2015, 06:56 AM | #11 |
Rep 217
Castrol Edge Titanium FST 0w-30 **
10,000 miles change intervals 2008 335d with 90,000 miles, no DPF, EGR blocked, and Ecotune stage 3 remap ** I did use 5w-30 but when Castrol brought out the improved TITANIUM FST formula I switched to that which is not available in 5w-30 yet |
06-01-2015, 08:16 AM | #12 | |
400
Rep 5,623
Do you think its worth going to 0w30 titanium? I use 5w30 castrol every 7-10k |
06-01-2015, 08:21 AM | #13 | |
99
Rep 477
Do you find it has helped allot using the 0w-30? In terms of the common black smoke that us non dpf 335d owners have?
06-01-2015, 09:07 AM | #14 |
27
Rep 214
Castrol Edge 5W-30.
Remapped, 118k. Doesn't use any oil between intervals. Cheapest place to get it from that I could find is below. http://www.ebay.co.uk/itm/3711328069...%3AMEBIDX%3AIT
// Diesel Power //09 335d//
06-01-2015, 09:52 AM | #15 | |
19
Rep 373
06-01-2015, 04:18 PM | #16 |
662
Rep 1,239
I like the black reek haha (I don't have dpf)
If your remapped but not planning on heavy track castrol titanium 5w40 might be a good oil to choose Like I say regular oil change is more important imo , and ll04 doesn't really matter if your running with no dpf |
06-02-2015, 02:29 AM | #17 |
Rep 217
06-02-2015, 05:13 PM | #18 |
12
Rep 80
Gulf gvx 5w30 - have dpf so using this. Opie recommended this to me as ll04 and also vw507 which is one of the hardest specs to meet so exceeds the ll04 by quite abit. Also cheap aswell. I think I got it at £23 for 5 litres
12-03-2015, 09:09 PM | #21 |
99
Rep 477
Yep true, i see now that they have the Mobil 1 new life, seeing that much more then the mobil ESP
