Used injectors available - 2009 335i 43,xxx miles
05-31-2015, 10:58 AM | #1 |
19
Rep 97
I have some used direct injectors available from my 2009 335i with 43,xxx miles. Part number is 1353 7585261-05 on all 6 injectors. The numbers on each injector (for coding) are as follows:
1) 579 230 2) 577 220 3) 581 236 4) 581 236 5) 575 253 6) 582 235 I just replaced the injectors in my car due to occasional misfires, rough idle, and some codes. These are the codes: 29D1,2,Combustion misfires, cylinder 5 29CF,2,Combustion misfires, cylinder 3 29CC,2,Combustion misfires, several cylinders I also had codes on cylinders 1, 2, and 4 but only once and that was after I changed the spark plugs and the codes may have been caused by a little oil dripping into the cylinder when the spark plug was out. So I believe that the injectors from cylinders 3 and 5 were the bad ones. If anyone needs any of these, let me know. I am in Berwyn, Pa - near the King of Prussia Mall. Dave |
