19x10 square setup on a xi
05-31-2015, 05:43 AM | #1 |
19
Rep 165
I have a 328xi and I know a lot of members already done the style 95 on there 3 series but i was wondering if anyone has some knowledge about what size tires I should get without messing with the Awd. Thanks in advance, please help!
And I'm on h&r springs! |
05-31-2015, 10:15 AM | #2 |
147
Rep 796
05-31-2015, 03:57 PM | #4 |
Where'd my VTEC go?
481
Rep 6,067
Square setup = same size tires on all 4 corners. 19x10 is going to be tough to fit on the front. Also that aggressive wheel fitment isn't going to look good if you're just on springs. You need to be slammed to pull off the look IMO.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
06-02-2015, 06:08 AM | #6 |
163
Rep 2,823
You can pull of 19x10 square setup, but there are few things to take notice.
First of highest offset that fits front without spacers are around et25 depends a lot of what brand coils. Here is one e90 with 19x10 et28 and kw coils and it's really close http://www.e90post.com/forums/showpo...1&postcount=37 Second you might need to get either camber plates to front or at least drill out the alignment pin to achieve some camber to front. Depending of the drive height, offset and camber i would say no more than 235/35/19 or 245/35/19 tyre to front and because you would have same size wheel and you have xdrive you need to use same size tyre at rear too. Well you could use 235/35/19 and 265/30/19 combo. Since you have lci and it has wider rear track i think you would be fine without rear spacer, but most likely needs fender roll to rear. This black e90 has 19x10 et22 with 235/35/19 front http://www.e90post.com/forums/showthread.php?t=349015
06-03-2015, 03:53 PM | #7 | |
19
Rep 165
Thanks man I really appreciated. I think I might go with 245/35/19 squared, and I'm also looking into the 265/30/19 combo as well. |
06-03-2015, 04:43 PM | #8 |
74
Rep 315
Drives: 2008 Deep Green 335xi 6MT
You can fit 265's up front?
06-03-2015, 08:22 PM | #10 |
28
Rep 265
I wouldn't recommend that tire set up.
For AWD, there are tons of threads that recommend under a 1% overall diameter difference between the front and rear. use this: http://tire-size-conversion.com/tire-size-comparison/ this set up you mentioned, the rear would be 1.9% smaller than the front. A common set up is the 235/35/19 front and 265/30/19 rear. Then again a 235/35 on a 10" rim will probably look pretty "stretched" and may not have the look you want. Maybe a 245/35 all around set up? if that fit's on the front without rubbing?
08 335xi- CP-E DCI's,VRSF 7" FMIC, UR Charge pipe w/ Tial Q BOV, JB4 G5, PE mod, 19" Sonic Tuning SC 7 wheels
06-04-2015, 12:00 AM | #12 |
19
Rep 165
Yeah I think Ima just go with the 245/35.. I can't wait to put on my wheels to see how they will look. Do you know any good places to buy tires? I been looking everywhere for a good deal.
06-04-2015, 11:58 AM | #13 |
28
Rep 265
Personally I'm not too picky about tire brand for the most part. I know plenty will disagree with me. I tend to go with new tires off ebay from reputable sellers. I bought 2 Saffiro 235/40/18's for the rear of my e46 about 6 months ago that I got off ebay, they were fine while I had it and sold it a few weeks ago.
I bought those 359's (In pics I posted above) last weekend and they came with 215s in the front and mismatched 255 and 265. I Just bought 2 235/35/19 Nankang's for the front and a 265/30/19 Federal (to match the other 265) from 2 different seller's for good prices. Tires should be in this Monday or Tuesday and I can't wait to get them mounted and on the car as well. I can't remember the last time I've been on stock wheels this long (about 7 months so far).
06-05-2015, 07:35 AM | #14 |
74
Rep 315
06-05-2015, 07:37 AM | #15 | |
74
Rep 315
255/40/18 front and 285/35/18 rear could be fun
06-05-2015, 08:39 AM | #16 | |
92
Rep 223
Tags |
328xi, style95 |
