2010 2011 BMW 5 Series Forum F10 N63 CCP & Engine Cooling |
05-29-2015, 07:14 AM | #1 |
29
Rep 122
Just had my N63 CCP completed (2012, 550iX). The car runs just fine. However, before the N63 CCP being done, when I switched off the engine the cooling fan ran for a period of time (5 minutes?) to continue cooling the hot engine, now it does not. Is this normal?
05-29-2015, 09:02 AM | #2 |
58
Rep 337
Yes. And if you read some of the articles about why the CCP was issued, this is part of it. The engine and turbos get too hot and the fan has to work overtime even after shutoff to cool it down to avoid (more) damage. This is what causes the extra drain on the battery which is why some N63 cars will need more frequent battery replacements.
Check the main CCP article, on the last page or two we linked some good reads about the whole situation.
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
06-25-2015, 10:08 AM | #3 |
148
Rep 284
I had my CCP done and the fan runs for a good long while after the car is cut off, they replaced everything but the timing chain as it had not stretched. So my understanding is the car is not suppose to run the fan for a while after the car is turned off after the CCP is done?
Doesnt make sense to me, if the car needs to cool off then the fans should be on right?
1985 Euro E24 M6 5Speed - Graphite Metallic/Black Buffalo Leather
1998 E36 M3 5Speed - Titanium Silver/Black Vaders 2011 550i X Drive M Sport - Carbon Black/Cinnamon 2020 M2CS 6Speed-Black Sapphire Metallic - Black Style 763M |
06-26-2015, 02:37 PM | #4 | |
1312
Rep 10,185
All depends on what the turbos need to cool down enough. So dont worry
BMW if you are reading, I need a job, Please. |
06-26-2015, 02:37 PM | #5 |
148
Rep 284
Thanks
07-01-2015, 09:59 AM | #6 |
253
Rep 735
im having problems with mine i only put like 1200 miles on for almost 2 weeks of having the car, im getting acceleration like studder and when its around 50mph -60 mph i see the traction control light going on and off and it doesnt pull the way it did once i got the car from the dealer but its a 2011 xi
07-01-2015, 01:03 PM | #7 | |
1312
Rep 10,185
Sensor feeding wrong info to ECU which then activates traction control and cuts engine power.
07-01-2015, 01:23 PM | #8 | |
253
Rep 735
are you sure on this? i hope so to be honest i love this car really not into getting into the dealership every month to get stuff done, |
07-01-2015, 01:29 PM | #9 | |
150
Rep 738
if its the sensor like hes saying, try disabling the traction completely off, and see if it helps
2011 550i
2013 M5 2014 M5 CP 2016 550i |
07-01-2015, 02:13 PM | #10 |
253
Rep 735
07-01-2015, 02:20 PM | #11 |
Rep 36
That is why I'm installing the larger air to water intercoolers from Dinan. Expensive but probably should have been larger from the start.
07-01-2015, 02:44 PM | #12 |
71
Rep 510
07-02-2015, 06:18 AM | #13 |
253
Rep 735
07-02-2015, 08:24 AM | #14 |
71
Rep 510
check out the pdf on what is not covered. They do cover most major components though.
http://cache.bmwusa.com/Pdf_16a4e27f...f-adbdaad31bd1 http://www.bmwusa.com/Standard/Conte...eoverride=true |
07-02-2015, 02:21 PM | #15 | |
30
Rep 307
Doesn't really work that way... the intercoolers cool the air charge into the motor from the turbos.. not the other way around. The turbo's are still going to hit their same temperatures regardless of what's inline on the cold side. Also read up on the stock intercoolers as many tuners can vouch the factory units working well with even high boost levels. I think larger heat exchangers would be beneficial over larger air/water cores. |
