2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing Suspension Problems
      05-28-2015, 08:12 AM   #1
ketema
73
Drives: 2015 M235i
Suspension Problems
Looking for some community comments.
1) I track my car a lot: every month since December except this last 2 months because of the issues I am having.
I chose KW DDC coil overs and paired them with Ground control camber plates. I have had nothing but problems.
1st Front left plate seemed to disintegrate. GC replaced plate free of charge and I had shop redo work. Next front right strut literally snapped the tip in the GC top mount. Needed a new strut and plate hardware. now the repaired front left has snapped as well. The second install on the right I used a different shop to try and eliminate human install problems. I am now leaning towards some sort of hard ware incompatibility. I am torn as to whether or not I should try the same set up again or get new plates or just get the clubsport kit which comes with its own top plates. I originally got the DDC because I wanted to have better than stock handling and retain functionality of the adaptive suspension. However with the cost of labor I'd rather just get something that is going to stick. Thoughts?
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
      05-28-2015, 04:49 PM   #2
foamie
Drives: M235i
I am leaning towards hardware incompatibility just as you are; something like the load delivered by one thing is not the load the other thing is designed for, or even the mating surfaces not matching. I think that your idea of using the clubsport kit is sound unless you drive the heck out of the car then this events could be considered "normal wear" Good luck !!!
      05-28-2015, 04:52 PM   #3
Liquidpaper
Liquidpaper's Avatar
451
Drives: '15 M235i
2015 BMW M235i  [0.00]
I'd lean towards hardware incompatibility as well. I havent had a single problem (knock on wood) with my GC camber plates with stock struts and H&R Springs. Kind of a shame -- the KW DDC coil overs were looking kind of good to me.
I'm kind of in the same boat as you (in terms of tracking and performance). I'd consider doing a clubsport setup some day, but I want to retain the "adaptive" element of the suspension (why oh why can't they make a clubsport that is adaptive?!?!). I was hoping (some day) that someone would come out with electronically controlled struts (maybe Bilstein or Koni) that are compatible and just run those with plates and appropriate springs.
I think as adaptive suspensions become more commonplace, more companies will offer more solutions -- when it works right, it's a really great setup for a daily that does track duty. When it goes wrong, well...
      05-28-2015, 07:07 PM   #4
i8ur911
125
Drives: F22 228i MSport
If you're tracking the car as much as you are, then I'd buy Clubsports. There should be no reason to retain the EDC if it's mainly a track car.
I'm also guessing that this is a hardware incompatibility issue, but like everyone else, its a guess.
Like you mentioned, the labor is getting costly if you continue to have this problem. I'd pony up and get a set of KW 2 way Clubsports.
      05-28-2015, 07:08 PM   #5
ketema
73
Drives: 2015 M235i
Pretty sure that's what I'm gonna do. Anyone want a used DdC Kit? In gonna replace the strut any way so it will be a complete set
      06-03-2015, 02:33 AM   #6
dt20011
dt20011's Avatar
262
Drives: 2014 M235i
How much?
      06-06-2015, 04:15 PM   #7
Liquidpaper
451
Drives: '15 M235i
I think this problem just happened to me on stock suspension with H&R springs. I'm taking it to the shop on Monday to diagnose. Hopefully if its the plate breaking they'll replace.
      06-07-2015, 12:06 AM   #8
dharo1
dharo1's Avatar
215
Drives: Previous: F22 M235i ; F80 M3 ;
Interested in outcome.
I will start tracking mine a little more often and want to be sure it doest become a common problem for all those tracking.
      06-07-2015, 04:24 AM   #9
ketema
73
Drives: 2015 M235i
Ground control and KW have been very professional for me. GC has replaced all parts for free in my instances. Please post pics and trouble shooting thoughts as you talk to your shops.
      06-07-2015, 10:08 AM   #10
Liquidpaper
451
Drives: '15 M235i
That's great news. I linked them to this thread in my email to them.
      06-08-2015, 06:54 PM   #11
Liquidpaper
451
Drives: '15 M235i
Update:
Took my car in and, yes, you guessed it, the camber plate sheared off the top of the strut.
My mechanic and I determined that it has something to do with the polyurethane that GC is using in their bushing -- its too stiff. Basically you have your steel strut fighting the aircraft grade aluminum camber plate the whole time. Guess who wins? Spoke to GC and they are thinking the same thing. They sent a sample of the bushings back to Germany a few weeks ago.
In the mean time, GC has created a new spherical-bushing based camber plate for the F80 that they are sending to me to fix this as a replacement (for both plates). Also, they are buying me a new strut.
So, OP, to answer your original post: no, its not hardware incompatibility. Did you get the new camber plates like I'm getting? If not, you should ask for a replacement.
      06-08-2015, 06:56 PM   #12
ketema
73
Drives: 2015 M235i
Yep they are on the way. Although not sure if I will use them as yet.
      06-16-2015, 07:45 AM   #13
chris82
chris82's Avatar
827
Drives: 128i
2009 BMW 128i  [9.80]
You're positive this isn't install error? What kind of shop installed it? Race shop? Local indy?
      06-16-2015, 08:44 AM   #14
ketema
73
Drives: 2015 M235i
It's impossible to say human error is NOT a factor. I tried to address that after it happened the FIRST time to me by using a different shop. It happened again. Both shops for me were highly recommended.
      06-16-2015, 07:39 PM   #15
Pparana
463
Drives: 2015 m235i
For what it's worth, I have over 2000 track miles on my Kmack camber plates, they have pillow bearings, and have had no issues with the added benefit of camber adjustment.
The force that caused the shock to shear on the bolt is Horizontal stress. The pillow or floating bearing should solve that, main reason I bought the Kmack ones to begin with. With the stock setup on lowered springs I could feel it binding on aggressive turn in on track. The failure vertical is probably the bushing.
I think for street they would be fine, but for liquid paper and Ketema who are at the track a lot, they just won't hold up. One things for sure GC will have to significantly redesign the plate for serious use.
Appreciate 2
      06-16-2015, 07:41 PM   #16
ketema
73
Drives: 2015 M235i
Completely agree.
      06-16-2015, 08:27 PM   #17
rwalker
330
Drives: the wheels off
Do you have pics of this setup? Turner sent me a set of KMAC plates, they don't fit (strut tower brace doesn't line up).
      06-16-2015, 08:42 PM   #18
Pparana
463
Drives: 2015 m235i
Yeah I can take some tommorow , I had to drill the strut tower brace, the press rivets are slightly off, as you probably noticed. Also under no circumstances use the supplied bump stops, they are way way too soft for the stock suspension. I am using the stock shocks with lowering springs.
      06-17-2015, 11:09 AM   #19
Liquidpaper
451
Drives: '15 M235i
Agreed. However, the new plates that GC is supplying to Ketema and me have spherical bearings/bushings, which should take care of this problem.
      06-17-2015, 08:07 PM   #20
Racer20
1030
Drives: F80 M3, 228i THP, E46 ZHP
It is not a shear or horizontal load. It's a bending load. In order to get more camber, the mount has to deflect more from straight vertical, (Or whatever angle is built into the strut towers). If you're trying to deflect a stiffer bushing, then you're going to be putting a huge bending load into the strut shaft.
A polyurethane bushing is a horrible idea for an adjustable camber plate. It's basic engineering, and seeing this failure is part of the reason I distrust so many aftermarket manufacturers.
If you want more camber than the factory gives you, you'll need a spherical bearing, and you'll get more NVH. No way around it.
Further, a camber plate with a urethane or stiff rubber bushing is NOT fine for the street: You may not have a catastrophic failure like this one, but you WILL wear out your struts much faster due to the increased side load on the seals and piston.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
      06-17-2015, 11:57 PM   #21
Liquidpaper
451
Drives: '15 M235i
Fair enough, but until BMW decides to make their own camber plates, we really don't have a whole lot of options. This car needs camber in order to track properly.
      06-18-2015, 09:09 AM   #22
chris82
chris82's Avatar
827
Drives: 128i
Had to do some research but I understand what you are saying now and I can see the problem with the OP's camber plates by looking at the pictures. I don't konw of anyone running into a problem like this on the E9x/E8x chassis regardless of the camber plate model so I am shocked to hear about this.
My advice to OP would be to buy the race plates which have the spherical bearing. I wouldn't worry about the NVH people claim they add because from my experience, they are silent. You will hear a slight increase in general road noise, but no clanks/rattles/squeaks. They get a bad rep because they're installed improperly. If they're professionally installed you will not get those noises.
And to rectify the previous comment I made, I do not think you're issues are install related, this was definitely the result of a design fault.
2addicts
