2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing Melted Cat
      05-18-2015, 06:19 PM   #1
Liquidpaper
Liquidpaper's Avatar
451
Drives: '15 M235i
2015 BMW M235i  [0.00]
Melted Cat
Ladies and Gents:
I melted my catalytic converter from (I presume) track abuse. Don't worry, they fixed it under warranty, but I am going to go get the Fabspeed HJS Cattled Downpipe to swap in from now on -- I can't afford to keep melting these things (BMW might get suspicious).
The shop foreman at Santa Monica BMW called me and said "Yep, looks like a lava flow in there." He was pretty cool about it actually. Props to them.
Anyway, for those of you who track a lot, please be advised...
      05-18-2015, 06:32 PM   #2
BMW GENIUS
153
Drives: 2015 AW M235i 6MT
I'm assuming mine will go out at some point sooner than I think at the rate that my car tends to backfire and crack at lol.
      05-18-2015, 06:56 PM   #3
mike@tpc
51
Drives: white M235i
you are lucky. My dealer wouldn't cover a damaged tire wear sensor today because I powdercoated the brakes....8500 miles ago!
      05-18-2015, 06:58 PM   #4
Liquidpaper
451
Drives: '15 M235i
Yes, I did get very lucky. Which is why I wanted to take preventative measures to make sure it doesn't happen again.
      05-18-2015, 07:43 PM   #5
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Originally Posted by Liquidpaper View Post
Ladies and Gents:
How did you find out it happened?
      05-18-2015, 08:19 PM   #6
Liquidpaper
451
Drives: '15 M235i
Check engine light came on (code p420). Took it into the dealer, and that's what they found.
      05-18-2015, 10:09 PM   #7
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
Tire wear sensor?
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      05-18-2015, 10:38 PM   #8
pikcachu
pikcachu's Avatar
1399
Originally Posted by alz0rz View Post
Tire wear sensor?
probably meant brake pads
      05-19-2015, 07:05 AM   #9
mike@tpc
51
Drives: white M235i
yeah, I meant brake pad wear sensor. They wanted $200 to change it out and clear the code. I paid $8 for one on rock auto and will have Markert Motor Works here in Atlanta clear the code for me and code the rest of the car for much less.
      05-19-2015, 10:32 AM   #10
Liquidpaper
451
Drives: '15 M235i
Okay, just ordered my new Fabspeed Downpipe with HJS Cat. Hopefully that will fix the problem. I'm going to the dealer today to pick my car up -- if they still have the melted pipe I'll take pictures.
      05-19-2015, 12:29 PM   #11
rwalker
330
Drives: the wheels off
what are your concerns with not running a cat?
      05-19-2015, 01:05 PM   #12
Liquidpaper
451
Drives: '15 M235i
1. Don't want the CEL; and
2. I hug trees.
      05-19-2015, 01:49 PM   #13
rwalker
330
2. I hug trees.
Ah.
On #1: it's likely you'll still get a CEL (eventually) on an aftermarket cat, if history is any guide.
I have no rebuttal for #2 .
      05-19-2015, 01:53 PM   #14
Liquidpaper
451
Drives: '15 M235i
Ah.
I don't think so about 1. It's an HJS catalyst (extremely high quality), which is specifically why I am going with Fabspeed.
      05-19-2015, 02:06 PM   #15
rwalker
330
I'm looking forward to hearing how you fare, then. This is a longstanding bugaboo with the N54 and N55.
      05-19-2015, 02:12 PM   #16
alz0rz
What goes here?
alz0rz's Avatar
450
Longstanding bugaboo with many cars, aftermarket 'sport' cats just do not seem to have the durability as an OEM cat used within its limits.
2019 G30 M550i
GBNF:
      05-19-2015, 02:13 PM   #17
Liquidpaper
451
Drives: '15 M235i
Is it really? I didn't know that. Thought it was just me being a maniac. Hm. Still, I can tell people "I DRIVE SO HARD PARTS OF MY CAR ARE MELTING."
Appreciate 2
      05-19-2015, 02:23 PM   #18
rwalker
330
To be clear, the bugaboo is the unavailability of a catted downpipe that works reliably with the BMW ECU on a long-term basis.
      05-19-2015, 02:47 PM   #19
Liquidpaper
451
Drives: '15 M235i
Oh.
Still, should be interesting to see if it works or not. And either way, I can't use the OEM pipe anymore.
      05-20-2015, 10:41 AM   #20
Liquidpaper
451
Drives: '15 M235i
You know, I've been thinking about it, and I am not so certain the catalytic converter should have melted here. I've been reading up on the causes of cat meltdowns like this, and normally they are due to engine misfires, running very rich, blown 02 sensor, fuel injectors, etc. My car has none of these problems.
Considering how melted down the cat was, I'm starting to come to the conclusion that this is a design defect with either the cat (or that cat was defective), or this variation of the N55 engine. It just shouldn't have this kind of problem, even from putting the car on track. It's a goddamn BMW. It's not like I'm banging off the rev-limiter all day and putting incredible stress on the engine, or making the engine itself too hot (it actually runs quite cool -- about 240 F) on the track.
Anyone have any insight on this?
      05-20-2015, 06:29 PM   #21
mike@tpc
51
Drives: white M235i
this is true. The only time I have melted a cat was when I accidentally switched the ignition wires to 2 cylinders when installing a supercharger kit on my old 350z.
I've got a ton of track time, but all of it is without cats on my 370z racecar. One hard trackday on the 2 and no issues though. If it was from running hard, I don't think you would be the only one, as others also track theirs.
      05-21-2015, 11:52 AM   #22
zipphreak
No_Country
454
Drives: m235xi
http://www.bmwe34.net/E34main/Trouble/Catalyticconv.htm
Most likely too rich, raw fuel hits the hot cat and ignites making it hotter and melts
2addicts
